AEtherScythe
- Leon
- Oct 11, 2020
- Michigan
- Ford Mustang Mach-E, Ford Escape Hybrid
- Sr. IT/Product Architect; Enterprise and Cloud Manageability Engineering
UPDATED 1/23/23 w/ the improved "Standalone" puck design. Scroll for where to download the 3D STL, strictly for non-commercial use.
Background.... I was very inspired by this thread over here: https://www.macheforum.com/site/thr...-arrows-to-indicate-proper-jack-points.23182/
So I set about to design my own solution for a MME jack/lift-point puck.
Here is the updated "standalone" version that needs nothing third-party, and is also taller to aid in use with lifts that span the majority of the distance between wheels (taller to avoid the frame that surrounds the battery):
A rendering of the standalone puck design:
For posterity, here is original "gasket" version that requires the third-party aluminum puck:
And here is the actual gasket / install aid, printed in flexible TPU 95A:
3D STL's of both versions are available below, and are shared as REQUIRES Attribution and strictly for NON-COMMERCIAL use.
You can print these yourself in TPU 95. If you print them for someone else, these should be passed along "at cost" e.g. your time materials shipping only, e.g. NON-COMMERCIAL.
https://www.thingiverse.com/thing:5779183
And here are the third-party aluminum pucks that were used for the original "gasket" version (per the other thread mentioned at the top):
https://amzn.to/3W2jHY6
