21st Century Pony
- Martin
- May 21, 2022
- Arlington, Virginia
- Ford Mustang Mach E 2022 Premium AWD ER
...or inconsistent in low volume manufacture QA? ...as in, welding the bushing stop washers in exactly the same spot?Ok, I understand a bit more. I have no slop in the bar to bushing or the bushing in the bracket. They are very tight and there is no movement in the bar whatsoever. Maybe the bar can slide a bit horizontally but I certainly cannot move it by hand and if and when it does move while driving, there is no noise. Maybe Steeda hasn't been consistent in sending out the same bushings and brackets with these bars?
Quality might be hard to consistently achieve, if the entire job batch is a small run (QA samples and all that...).
