SYNC install update date reads 'null' (no BlueCruise)
KevinS
The iOS Scriptable widget shows my SYNC version with an error in the install date:
Ford Mustang Mach-E SYNC install update date reads 'null' (no BlueCruise) SYNCnull
I am fully up to date on the modules via FDRS, but BlueCruise isn't activated.
I have redone the PMI process for APIM (using the official Ford procedure) with no alteration of the install date.
I have also reset the APIM via FDRS twice as is required in the BlueCruise update instructions.
Any ideas? Anyone else in the same boat? Anyone been able to fix this without a dealer visit?
phidauex
Colorado
Renewable Energy Engineer
Mine says "null" there too. Is anything broken? Not working correctly? I think you might be trying to fix a problem that isn't a problem, it is probably just a janky Fordpass API response.
BTW, I'm still at 2.3.0, and my Sync version in that display is 4.0.21281.
KevinS
KevinS
I am theorizing that it may be a symptom for why BlueCruise may not be activating for me (which I consider a problem.)
Blue highway
Mach E Premium SR RWD
Possibly. It seems unnecessarily complicated. The success rate of dealers appears to be less than 1 in 3. ?
smartino
Indiana
2021 RR Mach E First Edition, 2017 Honda Ridgeline
I have the exact same version for Sync as you do with a Null date. I do have Blue Cruise as it came via OTA. I am in the Early Access program.
Ford Mustang Mach-E SYNC install update date reads 'null' (no BlueCruise) 2882548D-59C1-4ADF-B72C-1525EE052A97
Prodigymd
New Hampshire
Mach-e
Mine is the same! The dealer installed all the updates along with 21G01. My sync version is still 4.0.21281 and I’m at 2.3.0.
I actually lost active cruise control too and the steering wheel button doesn’t do anything to activate/deactivate.
my last updated also shows null. This is all inconsistent ??‍♂
Ford Mustang Mach-E SYNC install update date reads 'null' (no BlueCruise) 62A6EAA3-04C2-4169-867A-601507323AA2
Ford Mustang Mach-E SYNC install update date reads 'null' (no BlueCruise) 5C865D2B-AC6D-44EF-A7A8-37C0C0AE6BDE
Logal727
C
We’ve been over this multiple times in different threads, this has nothing to do with your problem, the date falls off after the last OTA update I think like 3 months.
KevinS
KevinS
I had not seen that there was a consensus that this was not an problem. So, apologies.
For me, this only came up with the last round of BlueCruise updates via FDRS - prior to that, install date had shown without any problems.
Logal727
C
Yeah it’s just a coincidence, mine changed too and I’m still on 2.3.0, 3 months after I got it, it just falls off the server I guess after that time
Ford Motor Company
Official Ford Account
Hi there! Are you still experiencing these issues? If so, would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
mpshizzle
Utah
Mustang Mach E 4X
Took it to a dealer on Monday evening, they called the hotline Tuesday, as of now they still have not heard back.
On Wednesday I got tired of not having a car (this is my only vehicle) so I took it back and they dealer supposedly will call when they hear from Ford.
Been working with several forum members to try and figure this out but so far no luck.
My next plan is to start running PMI on all of the modules involved with 21G01, as suggested by @benk016
I'm beginning to worry this will be a situation like 1.7.1 where Ford takes months and says nothing while they figure out a fix
As a side note, part of the confusion here may be due to a similar issue, where FDRS was not showing all of the updates, and cars weren't getting all of the software. This has been solved. The cars with this issue show hands free in sync, with current maps and all. Just no server side activation
mpshizzle
Utah
Mustang Mach E 4X
Sounds to me like an update or two didn't install correctly. I don't have the ability to check for DTCs, but if you send your VIN I can at least check it there's software updates showing for you
Prodigymd
New Hampshire
Mach-e
Supposedly, the dealer contacted ford and all the updates are through. They had an engineer walk them through the updates and still no go with the steering wheel button, adaptive cruise control, or bluecruise. Job 1 AWD ER 2/21 here. They’re ordering an instrument cluster, apparently that’s where the issue is. I remember when I first got the car, I was never able to “disable” the blue bubble and have the speed in the middle of the instrument cluster. No matter what setting I had on/off. I wonder if this issue was present since day 1 and I never gave it a second thought. ??‍♂ I’ll PM you my VIN! Thank you!!!
