EVer
San Diego, CA
Yes I think you're right, the only connector used when connected to a DCFC for the J-1772 part of the connector is the one pin that makes the hand shake with the vehicle.
I think 3 contacts from the J1772 portion are engaged during DCFC: 3, 4, and 5.
Ford Mustang Mach-E The truth about Electrify America's progress and Traveling with the Mach E 62316CE0-C2D3-48E3-BBBF-07D5D3D3A42D
Yes but that still leaves the CCS1 vs CCS2. This difference will prevent moving cars between North America and Europe. Not sure where the rest of the world falls on that one.
ClaudeMach-E
Claude
Quebec Canada
Mustang Mach 3- Tempo- Malibu(3)-Actual Kia Sportage AWD
Have you guys ever seen the same standard for anything in EU/UK vs NA, NTSC-PAL, 240V system vs 120V-50hz vs 60hz and others, ;) I don't see the day yet where that will happen.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Military personell stationed overseas will frequently ship their cars there for the term of their stay.
At any rate, there are adapters for the different plugs (indeed we've seen pictures of EU Mach-E's charging at US stations using an adapter).
DBC
Don
Volt ELR
Yes. It's the same standard. The difference is that in CCS2 the AC part of the combo uses a Mennekes connector just to give the German manufacturers a plug. (JK but true). With CCS1 the top AC plug is J1772.
ClaudeMach-E
Claude
Quebec Canada
Yes a some Petro Canada 150kW to 350kW also, but Ford Pass I believe would work with EC.
