2FlyMache
- Patrick
- Aug 9, 2021
- Martinez GA
- 2021 Rapid Red Ex4 MachE
Didn't change out the rims as these fit the stock rims. They do handle better for sure. I was seeing the review on the Hankook and it looked like they should be okay in wet conditions. I don't have to worry much about snow in Georgia so the all season should be fine. I'll keep the DWS + as a backupWheel weight can also affect your efficiency. If you’re in a warm climate the hankook ions will work but they will it handle even light snow. You’ll give up some dry traction and ride quality the biggest deficiency will be wet handle and braking distance. Also most of your rolling resistance comes from the hysteresis of the tires sidewalls. Eco tires have to use a reinforced sidewall and a rock hard compound to make a meaningful difference in rolling resistance. If you didn’t go aftermarket on wheels then the 245 will be at the limit of its mounting width and you’ll be really flexing those sidewalls which will really add to rolling resistance.
