Pushrods&Capacitors
- Brian
- Jun 24, 2021
- Round Rock, TX
- ‘21 4X, ‘14 SS Sedan tuned, ‘17 WRX tuned
- Analyst
My SS EPAS failed May 2017, on a curvy stretch of 2222 in Austin, fun times. But I was under the CPO warranty and back on the road in 5 days. Recall came down like a month or so later I think.Lol oh yeah, I should remember that too since my EPS on the SS went out ….. 3 weeks outside warranty and before the recall. Had to pay out of pocket to fix. Didn’t get reimbursed for a whole year until they finally recalled it.
But yeah, either way, we still got a lotta junk under the frunk.
Whatcha gonna do when you find out about the time limited power on the Blazer though?
This is a LOT of work to get full power on the hummer and it sounds like the Blazer will have a similar setup to “watts to freedom.”
https://www.gmc.com/support/vehicle/driving-safety/ev-driving/watts-to-freedom
HOW TO ENTER WATTS TO FREEDOM MODE
Watts to Freedom unlocks maximum torque, allowing for extremely fast acceleration.
To ensure you are deliberately engaging the feature, Watts to Freedom requires several steps to engage. Follow these steps to enter the mode:
a. To confirm, use the steering wheel controls.
- First, bring your vehicle to a complete stop.
- Press the StabiliTrak/Electronic Stability Control button, located on the instrument panel, twice. The button looks like a vehicle with two curved lines trailing from the tires. You’ll see an animation in the cluster and feel vibrations in your driver seat when you do this.
- You’ll see a pop-up on your infotainment screen asking you to confirm that you want to engage Watts to Freedom and lower the vehicle.
4. Once you confirm that you want to enter Watts to Freedom, your vehicle will begin to lower.
a. While lowering, it will change settings for the shock absorbers, accelerator and cooling system to adjust to the enhanced torque the mode offers.
b. You will see an animation on your display as well as a Torque Gauge Capability graphic, which indicates the vehicle’s readiness for enhanced torque output. The bars atop this graphic fill as your vehicle conditions itself for enhanced torque output. Once the bar is full, you will have access to full torque.
c. The orange bar in the middle of the screen shows the amount of torque available at the current moment. The blue bars represent your vehicle's progress toward activating the Watts to Freedom feature.
5. You will then see a prompt on the display that instructs you how to brake to start the Watts to Freedom sequence.
a. Use your left foot to press the brake pedal with the appropriate pressure to proceed to the next prompt.
6. While you’re holding the brake pedal down, you’ll see a similar prompt for the accelerator. Use your right foot to press the accelerator pedal to the floor to confirm this prompt. When you do, you’ll hear a ramp-up sound that sounds like an engine hitting its revolutions per minute limit.
7. The infotainment screen will then prompt you to release the brake pedal. WARNING: As soon as you do this, the vehicle will launch into an extremely fast acceleration.
8. The vehicle will then accelerate rapidly. You will see your Torque Gauge fill up and see a message indicating the level of acceleration you're experiencing. Maximum torque output will disengage if you exert any significant steering input or experience a stability control event. The feature's state will return to step 5, detailed above. You will be able to reengage acceleration after following the engagement steps again.
9. To slow your vehicle after the acceleration event begins, release the accelerator pedal and press the brake pedal.
As for the Blazer SS and WOW mode, I’m not worried. Because I’ll bet dollars to
Donuts that they’ll implement it like BMW, Kia, Hyundai, Porsche et al. where you get the full 550/650 for 10 secs and then down to maybe 450/500 or something. They’ll spec it and detail, unlike Ford’s “cover up” 5 sec that was never divulged ahead of time. Plus, HUD and cooled seats are so good. Remember? Haha
