To PPF or not to PPF, that is the question
How much PPF?
  • Total voters
    116
VaderMachE
Robert
Fusion Hybrid, Mustang Mach E! (Shadow Black)
Supervisor
I don't think people really understand how easy it is to do the ceramic coating yourself. All you do is wipe it on, let it haze, wipe it off. Instant 1-3 years of paint protection (depending on how well you take care of your car).
It's also two completely different things. PPF protects against physical damage from bugs and rocks, ceramic coating protects your clear coat from fading away from elemental damage and also makes it way easier to clean. If you don't want to do ceramic coating at least put a paint sealant on your car every 4-6 months depending on where you live and if it's outside or in the garage.
Saying no to both is like saying you don't give a damn about your car. PPF isn't for everyone but at a minimum at least protect the paint with a sealant of some kind.
I keep my fusion protected with a sealant (not ceramic) and I can go through a touchless car wash once a week and it looks like I completely cleaned my car because nothing sticks to it. I'll do a full hand wash maybe once a month. With the MME I'll be doing a ceramic coating. I didn't do it on the fusion because I'm getting rid of it anyway.
Also doing PPF on the front end back to the mirrors because I can only imagine how many bugs and rocks are going to be tagging that giant front area.
You're so correct! The prep work is where the sweat equity comes in. Clay bar and any paint correction is all you need to do prior to ceramic coating, and even then, the amount of work depends on how much of a mirror you want your ride to be.?Keep those MME's shiny!
blue92lx
Adam
Ford Fusion
The first time I did a clay bar I was amazed at how easy it was. It has all this hype built up around it like 'omg I got my car clay barred' but you just throw some detailing spray on it and wipe the bar around. It's so freaking easy to do lol. I was like.... what? That was it?
blue92lx
Adam
Ford Fusion
Someone's Start White get a little ceramic TLC in this short YT video.
And that's it. That's the 'mystery' behind ceramic coating. You wipe it on, you wipe it off. I feel like it's been this mysterious thing that only a professional detailer could do, but now that so many real ceramic coating products are available to the public we can see how it's not really a big job to do. Like Vader said, it's just doing some prep after a car wash. Wash the car with your car soap and a little dish soap mixed in to remove any wax/sealant on the car, clay bar if necessary (will give you that glass feel and also remove any additional sealant/wax), wipe ceramic on, wipe ceramic off. You now have years of protection on your car.
If you want to then protect the ceramic coating you can wait a little bit and put sealant on top of that, or for even more shine maybe some wax.
EELinneman
Eric
Littleton, CO
Sr. Dir Cloud & Projects
Adam,
There are some professional-only products out there and some commercially available also. I think that Patrick of the Mach-E Vlog and his wife Liv were doing a video of this. They published one on do-it-yourself PPF which is excellent.
We are now at the limit of my knowledge of this. I do know wax, but am learning about ceramic.
blue92lx
Adam
Ford Fusion
Adam,
Check out Larry's video, the amount of detailing information he has on his channel is amazing. But this is his 'ceramic' coating (it's actually enamel and not ceramic but does the thing). He also has an extensive Q&A for the last half. He goes into using products on top of the ceramic coating, how long to expect it to last, etc.
Scooby24
Olathe, KS
Perioperative Revenue Manager
I'd advise a bit of caution on this approach as it's unfortunately not that simple in practice. First, the clay bars do some micro marring of the paint. In the right lighting you will definitely see that after a clay (even a fine clay or a clay sponge) you will need to do paint correction prior to ceramic as well. You need the paint surface completely corrected before application.
The application itself is not as simple as it looks. It's a WEIRD product. It goes on somewhat thick compared to other solvent type products and it doesn't all flash off. You have to time the removal right and that timing has to be checked as every coating will react differently and will also react differently with every day based on conditions for humidity and temp. If you remove too soon, you remove too much. If you remove too late, you get uneven heights which produces a rainbow effect. If you don't have the right lighting, you won't see these results as you're applying and may not see the mistakes being made until it's too late.
Now it's absolutely true there are consumer grade products that are MUCH more user friendly and forgiving with these caveats....but there's USUALLY a trade off.
One product that's not quite SiO2 but still produces similar results while being WAYYYYYY easier, is Meguiars hybrid paint coating. Durability results look downright impressive.
Mach-E VLOG
Patrick
Oceanside, CA
machevlog.com
We did DIY PPF on the front half of our Mach-E followed by DIY ceramic. The PPF install was a huge effort, but can be done yourself if you have the time and patience. Ceramic was far easier, but still requires a bit of time and you have to be careful in how you apply it. Neither was perfect for us, but we learned a lot in the process -- both about the products and about the Mach-E's body.
TRP
Mach E P4x, Ford F150
This will be the first car I've had it done on but I'm doing both.
PPF - full front, mirrors, A pillars, B pillars and ALL exterior gloss black around the lower part of the car. Professionally installed. There are a few other places here I "may" do myself, undecided at this time. Cost of install - $3000
Ceramic Coating - Full car even over top of PPF. Cost $300, should last about 1 year. If it gets close to that and I really like it I'll pop for a better quality version later
jonkMACHE
JK
NYC
MME 4X
Everyone has different tolerance if a PPF/Ceramic is "worth it." I like having a factory-looking paint job on my car, so for me it's worth it. If you're ok with the chips and scratches that will accumulate over time, you likely don't need it.
Ceramic and PPF have different benefits and my personal recommendation is to get the front PPF'd and the entire car ceramic. I don't think it's necessary to do full PPF and would only do that if I had something crazy expensive like a Lambo or a Ford GT.
Ceramic creates a hydrophobic surface over your car's paint. Ceramics are also very "hard" and so it also creates a thin clear "shield" over your car's paint. In layman's terms, the surface of your car will be super slick and dirt will slide right off without much effort. This is particularly helpful when a bird poops on the car and it gets baked in by the sun. With ceramic it'll slide right off, but with no ceramic it'll require a little scrubbing which can scratch your car (bird poop usually has fine sediment in it). Typically, I don't even need to use soap when I wash my car. I just rinse it off with water, and everything comes right off with a microfiber cloth.
PPF protects against rocks and gravel that get kicked up when you're going 80mph down the interstate. Provided the rock doesn't actually dent your car, PPF is really good at preventing scratches. Since nearly all rocks will be directed at the front of your car, you really don't need to PPF anything but the hood, the grill, left and right fender, and maybe the black trim if you really want to go all out.
There is a noticeable difference in the way a car will look in a few years. Pulled next to a FE blue MME the other day... his paint looked horrible. Scratches everywhere and the paint really lost its sheen. But it's up to you if that's the sort of thing you care about.
Oh... and also... do not run your car through an auto-wash if you value the paint job. Hand wash only.
joebruin77
'18 Tesla Model 3 Perf, '22 Mach E GTPE
I am scheduled to take delivery of a 22 MME GTPE in about a month. Although I have loved the Xpel PPF on my 2018 Tesla P3D, I've decided to skip the PPF this time. Shortly after taking delivery, I plan on doing a full wash and decontamination, followed by a DA polish using Dr. Beasley's 45 NSP polish (no IPA panel wipe required), and then I will apply Gyeon Cancoat Evo. Cancoat Evo is a very user friendly ceramic coating that is literally wipe on, wipe off. It should provide over 12 months of protection.
I enjoy car detailing and am confident that I can handle any scratches, swirls, and rock chips. But if you are not into that and keeping your paint pristine is important to you, I highly recommend PPF. The self-healing capability of PPF is truly amazing. Here is a great video that demonstrates how the film heals itself and the scratches just magically disappear (skip to time mark 1:15 to see the guy take a metal brush to his car paint and purposely induce some scratches in the clearcoat. Then watch them disappear when he applies some heat):
jonkMACHE
JK
NYC
MME 4X
Nice video.
joebruin77
Nice video.
I thought it was funny how the guy practically had a panic attack when he purposely scratched his paint with the metal brush. I totally empathize and would feel the same way.
jonkMACHE
JK
NYC
MME 4X
Yep I would feel the same way
Ciber 2022
Pierre
Gatineau, Québec
Mach E GT performance 2022, Mustang GT PP2 2019
I’ve chose full PPF as I’ve done on my 2019 GT performance package level 2. Actually, the vendor of XPEL is starting on our car today
