Tolls Not Detecting IPASS
Mach-e Gt
Now, before someone said to put in the dotted area, I did and it is very inconsistent and sometimes, the tolls won't even register it. I have gotten invoices for unpaid tolls and I'm getting annoyed. I am going to get more Velcro strips to try the left side and see if that is any better. Any one else has this problem?
Ford Mustang Mach-E Tolls Not Detecting IPASS 20240227_232942
orangethunder
On order
Have you tried the new iPass sticker (replaces the transponder). Had good luck with sticker used in other states.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Try lowering the transponder to the bottom of the dotted area. It seams that the roof edge may be blocking the signal. My transponder works fine in this position.
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
In NH, we have EZ Pass. Our fancy IR blocking windshield was interfering with the transponder so I changed to one mounted on the front license plate. NH requires a front plate so I did not have to drill new holes.
GatorGrowl
United States
2023 Mustang Mach-e Premium ER RWD
All I tell you is I have a Florida SunPass and with the transponder in the middle of that area it works fine.
CB1234
2022 Mach-E Premium AWD ER
Also it looks like you have it mounted upside down? I'm guessing if you flip it and lower it a little you'll have more success.
I have the same type of IPass transmitter and haven't had a problem with it a little lower and right-side-up.
ktgeek
Keith
Bartlett, IL
'10FusionHybrid,'18Expedition, RapidRed MME AWD eR
A couple years back (I'm a Job 1 owner) i had that same problem. The tollway folks took that style transponder back from me and gave me one that mounted on the front license plate. They said something about the coating in class in EVs causing interference/signal blocking.
I see others saying to try different locations, but with ipass switching over to stickers it might just be time to get on the future train.
Ford Mustang Mach-E Tolls Not Detecting IPASS IMG_0804
VindictivePantz
Arlen, TX
2021 Mustang MACH-E Premium AWD w/ Ext. Battery
Mine is on the left side, in the dotted area. I believe the manual states recommended placement.
Orangedepressed
Mach-e Gt
Honestly, sticker for the license plate would be a lot easier since all I can see through the pics on the invoice is my bright license plate lol. I assume that the sticker is waterproof. I might have to see if I can apply for one.
Wally
Wally
Arlington Heights, IL
2021 Red Premium Mach E4
Prior to the new sticker IPASS had a transponder that mounts onto the top of the front license plate on the outside of the car. this is what was recommended.
Orangedepressed
Mach-e Gt
So I went out and got an Ipass sticker. This requires me to stick it to the inside. Could I still put it on my plate?
Ford Mustang Mach-E Tolls Not Detecting IPASS 20240228_094730
Our EZ-Pass transponders have the same form factor (and thus are likely the same device electronically). Mine is mounted in the same location and I’ve never had read problems in PA, DE, MD, VA, or the DRPA.
Sounds like that would only work for cars with front license plates? Also, wouldn’t that be further from the overhead gantries and possibly blocked by engine components in ICE vehicles?
