Only every single time.3). When you punch the gas pedal and take off ... does everyone giggle like a school girl?! Holy smokes!!
Perfectly normal question. Would advise checking out this post on why it is commonly referred to as the guess-o-meterCharging…why does my Ford pass say it’s aiming for 100% battery but will only have a range of 231 miles? (I thought the GT is 270 miles)??
Nope I have not. If you find it before me please let me know. I'll bookmark this thread as well so if I figure it out I'll let you know.Did you ever find a solution?
Okay, Im going to watch for a couple weeks.Ummm, might be related to your question #3! Others have called this the Guess-O-Meter or GOM. It seems to get more accurate the more you drive the car. I'd suggest give it a couple of weeks and see what it says and how accurate it is.
Thanks, Ill do the same. I have to replicate it a few times to see whats up. I had similar on my ford Edge when I first got it. I had the guy drive with me for a while and listen...very similar noise.Nope I have not. If you find it before me please let me know. I'll bookmark this thread as well so if I figure it out I'll let you know.
Thanks, Ill check it out. And anyone can give me a hard time... I dont care. Call it a lightning pedal, "the thing on the floor on the right" or whatever... the point will get across.Congratulations on your purchase and welcome.
Be cautious about calling it a gas pedal, some people will give you a hard time
https://www.macheforum.com/site/thr...ulate-how-far-your-mach-e-can-really-go.6104/
What, no accompanying picture??? Nothing better than to see a new MME on the road!!! Congratulations and enjoy.Took delivery of my GT last night. I have a few questions if anyone with knowledge can answer:
1). Has anyone heard a slight metallic "rattle" near the passenger seat dash area? Only on the roads that are not perfectly smooth and without the sound system on.
2). Charging with the included charger. I have it pluged into a 240v outlet. (number 6 wire and a 50amp breaker). According to Ford Pass, it is currently charging at 7kWh and I have added 18 miles in about 1 hour and 16 minutes. Does this seem accurate? Is there something I need to do to make sure its on the max setting (inside the car or on the charger/app)?
Thanks!
Please don't do that if the system isn't rated for it. A 32A charger should be run on a 40A breaker. You need the 20% derating due to the sustained high load.Do not forget that 8% of that charge power is lost in inverter efficiency. So what is 7, is really 7x.92 Or 6.44 kWh To the battery. I have used it on a 30 amp breaker many times and it did not trip, and by kW calc, I think it really gives 28 true amps @240V or 6.72 Kw or 6.2 after efficiency loss. Some day I will measure it at the panel and report it.
“Hit the gas man! Hit the gas!” ?‍<snip>.
<snip>
Just call it the GO pedal.Thanks, Ill check it out. And anyone can give me a hard time... I dont care. Call it a lightning pedal, "the thing on the floor on the right" or whatever... the point will get across.
