Pushrods&Capacitors
Round Rock, TX
ā€˜21 4X, ā€˜14 SS Sedan tuned, ā€˜17 WRX tuned
Analyst
Yeah I think this is where Tesla has it, they just dump a bunch of power to the motors and you get that head snap effect. Which is definitely fun.
Makes me curious if the 0-60 on a MME would be faster if you did a quick roll in on the throttle instead of just mashing it to the floor.
Might also be why they quote 0-60 time after the 1ft roll out, but I think that might be an industry thing too because they aren't the only ones doing it.
EDIT: changed it to 1ft roll out
Yep, Tesla definitely lets all of the hp/tq hit instantly, thatā€™s for sure.
As for 1 ft roll out, on my dragy runs the FE loaner was mostly 4.9s to 60mph and with 1 ft roll out it was showing 4.7s, but, since I deleted the runs out of my app now I canā€™t go back to screenshot/post them. Grr. Oh well, our 4X should be by early Oct. so Iā€™ll post up vids/slips then I guess.
Here is one for my SS sedan/Commodore SSV Redline though, TCS on so the launch was soft but it hooked pretty good for 39F and max perf. summer tires (Conti ExtremeContact Sports). Personal best is 12.28@116 but that was on prepped track and a 1.89 60ft.
santa fe,nm
www.envirokarma.org
Solar Sales/install
Took our Premium EAWD to the track, car has 295/40 rear and 255/45 front tires so it should 60' very well but it's SLOW!!! Ford should be able to easily get. 5 second faster off the line with just an update to the programming which would easily make this a 12 second car. 13.6@102 ain't bad though. Sorry everything is in vertical so I could post to tiktok as well :)
Ford Mustang Mach-E Took my Mach-E Premium EAWD to the track for some drag racing (timeslips + videos) 31F57BB8-1E37-4082-B931-1B7234C94A55
Links to videos:
https://photos.app.goo.gl/LDkKN4orcAqsf6h18
https://photos.app.goo.gl/eb5LX3nbFhY8DjAj7
https://photos.app.goo.gl/CzbGt2YmZZBaVaFL8
I heard in the video that you had traction control OFF, which would have been my first question. ;)
second question is whether or not you held w Brake, and hit throttle one light early, releasing brake at the light......or just stomped throttle at the light?
Nope stock stall/trans/driveshaft/axles at that time, same with many others.
The V is amazing for getting off the line for being a fat pig.
Here's a video of it at the track with a 1.507 60'
Why does the car keep jerking? ???
db4z
TX
Focus RS
What was your battery SOC? Max power must drop at some point with decreasing pack voltage.
pt19713
Sort of. In the Model 3 there's a lot of torque instantly. In the Y, they dial it back slightly until 10 mph. Attached is a 0-60 on the Dragy, 2020 Model Y Long Range with the acceleration boost. Stock 19" all season tires, 86% SoC. You can see the initial acceleration being held back. The Y Performance has the same acceleration curve.
blue92lx
Adam
Ford Fusion
What model is the first edition? Seems like your draggy app is showing almost a full second faster than advertised which is odd.
Pushrods&Capacitors
Round Rock, TX
Analyst
Premium 4X, Ford says 0-60 in 4.8 and thatā€™s what the mags are getting. It was spot on for the 5-6 runs we did, SOC was between 85-90% and it was actually a bit damp out.
You did see that the dragy run I posted was for my SS sedan, right? ?
Pushrods&Capacitors
Round Rock, TX
Analyst
Yep, that LSA gets things going quick.
I doubt a Mach E GT PE will beat 1.5 60 fts. Maybe equal but not beat. Defense definitely wonā€™t have the top end.
pt19713
It won't be close. It'll need to be a 9 second car (1/4) to get a 1.5 60 ft. Here's the Model S Plaid
The Y Performance does the 60 ft in about 1.85-1.90s, so the GT PE will be close to that.
Blinkin
James
Zip Code: 48124
16 FoST
The 60' time is killing the run. I bet it is the electric nannies on the car, as you note.
As a long-time drag racer, i have been a bit surprised with the Mach E from a dig. Clearly being held back by the computer. Gun it from 10 or 15 mph and it throws you back in the seat. Will even break the wheels loose a slight bit. But from a complete stop, the power delivery is definitely being throttled.
Future OTA for "launch control" or similar? Or maybe that is just for the GT...
There's a lot of untapped potential there, I agree. My guess is that Ford is trying to make the premium lean more towards luxury than violence. Probably an intentional choice unfortunately. Maybe an optional software update someday?
Pushrods&Capacitors
Round Rock, TX
Analyst
Many cars that launch hard can net 60ft times in the 1.5s, especially if theyā€™re AWD. My daily SS sedan has cut a 1.89 60ft on a prepped surface with just max Perf summer tires and itā€™s RWD. Our tuned WRX has gotten down in the 1.5s on the street and itā€™s only making about 375Hp to the wheels. It did 1.6s bone stock with a 6K rpm clutch drop.
If Ford decides to turn the GT PE loose on launch, 480/634 is gonna be good for much better than 1.85-1.90 60fts, regardless of what Tesla is doing with the Why Performance. Bank on it.
MachMachWhoThere
Pennsylvania
2021 Mustang Mach E GT Iconic Silver
Iā€™m so grateful for this thread. Itā€™s got me looking up nearby drag strips, and I found one about 40 minutes away! Iā€™ve got a non-PE GT on order, and this sounds like too much fun not to try!
Iā€™ll be a total noob, but got to test it out lol.
pt19713
You're telling me that a Model 3 Performance, which weighs 800 lbs less, cuts a 3.1s 0-60, 11.5 @115 mph quarter, 60 ft on street tires 1.80, and the GT PE will shave off 0.3s from the 3P's time?
Pushrods&Capacitors
Round Rock, TX
Analyst
What Iā€™m saying is that it is possible depending on what Ford engineers decided to do with the launch control programming. Your Tesla comparison is only one data point. Edit: and to be clear - the GT/PE will not beat an 11.5 1/4 mile, Iā€™m only saying Ford can get the 60 ft times lower than 1.8s, after the launch the higher weight of the GT is going to be the limiting factor. So, with 1.5-1.6 short times I think a GT/PE could be a 12.0-12.2 1/4 car, trap speed maybe 112-113mph. If you look at Tesla Y and 3 acceleration times youā€™ll notice a disconnect between their initial launch G and 60 ft times vs. their 0-60mph and up times. Their 0-60 times over-perform their 60ft as opposed to ICE cars that launch really hard. I suspect this is because of throttling the power in initial hit and then quickly ramping up to max once traction is established.
Will Ford turn the GT/PE loose? Who knows, but if they want to give it an ā€œuntamedā€ launch control option I can see 1.5-1.6 60 fts as a possibility. They probably wonā€™t do it for warranty reasons but one can dream.
