Waps61
Waps
Netherlands
Mach E RWD SR
Its possible that the low voltage was causing the modules to report weird numbers, and also why so many modules start throwing errors.[\QUOTE]
Plausible
Its just odd that the high voltage is engaged, because the AC compressor is running, but, its not supplying any voltage to the 12v system in that state.
This why there has been e recall for pre March or Feb production cars; owners were locked out of their cars.
It is not even charging when the car is connected (charging or not)... The manual does say something about this.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Mine is definitely a pre Feb model. Built in December.
Sounds like another TSB I need to add to my appointment for next week to be addressed.
Polar
SBJ
PNW
2021 Select RWD SR
I got nailed last night - totally dead MachE this morning.
Damn funny runny my 8amp trickle charger in my car this morning.
Oh the thick irony of the 12V dying while the 400V was getting charged.
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process 1CADBAB2-81FF-48BF-9773-5DBD7FDBD597
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process 6A0AA163-5D2B-49A7-A90F-9BA803C1A92B
To be clear - had been charging the previous night from about 50% to 100% in prep for a road trip. Which we didn’t get today ?
Crilly
Dale
Hartland, Wi
Livewire prius prime Mach e. In 3 weeks if it was built yesterday
Make sure you turn off the 30 min off timer. Make sure the car is on and not on accessories.
LadyGator
Brittany
Houston
Mach E, Ext. Range
Is it not able to be jumped fully from another vehicle?
Yes, it can be jumped from another car if you do it carefully. Although easy enough to throw a battery charger on it if you're not in a hurry.
LadyGator
Brittany
Houston
Mach E, Ext. Range
Ok, one more thing I will need to read up on for this car when I get it back. I'm still not sure how to have it towed or get a jump if I need to.
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process 267
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process 268
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process 269
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process 270
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process 271
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process 272
benk016
Ben
Tulsa, Oklahoma
Just to be clear, This happens even if the car is ON and plugged in.
I've been in the car, with it ON, but not "READY" because its plugged in. The car is on because the AC is on and working. But between 30-45 minutes the car will start throwing all the errors because the modules are going offline as the voltage drops.
The last time It happened, one of the modules I was connected to was reporting it was running at 8v. I got out and unplugged the charging cable and "started" the car again and the voltage jumps to 13v and it starts charging the 12v battery again.
Tyldum
Norway
Mustang Mach E First Edition
The 12V state is available in the FordPass API, by the way. I monitor it using my smarthome (Home Assistant).
It does generally drop just when AC charging starts, then quickly recharged. No data on DC charging yet.
Ford Mustang Mach-E TSB 21-2091 - 12-Volt Battery Becomes Discharged While The Vehicle Is Plugged In During the High Voltage Charging Process Screenshot_20210804-233515_Chrome
Fordmaybe
Joel
NH
No ford yet
Manufacturing
Where is the API for fordpass?
Looking into this, the 12V parameter is called "batteryStatusActual" in the JSON the FordPass API returns from the server. However it's of limited usefulness because it only returns the battery voltage to the nearest volt (disappointing), which isn't enough resolution to determine the battery's charge state accurately. In addition, the value returned may be a reading from hours ago when the car was last turned on rather than reflecting the current state. It does not update while the car is off or likely during a drain event. As you can see, a value of anywhere from 12 to 15V is encountered in normal use. The only indication of a problem would be a reading of 11V or less, at which point it might be too late. Again, not very useful to show battery drains IMO, really only shows charging activity.
Tyldum
Norway
Actually, there is an additional field for battery health as well, which I presume is based on more accurate data.
breeves002
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
Battery health just returns "status_ok". I do not know any other possible return values it has or if it is 12v or HVB.
