breeves002
- Sam
- Feb 21, 2021
- St. Louis, MO
- 2021 Mach-E GT PE
TECHNICAL SERVICE BULLETIN Illuminated MIL And DTC P061A, P1A1E, And/Or P2533 - Built On Or Before 7-July-2021 | 21-2244 02 August 2021 | |||||||||||
Model:
Issue: Some 2021 Mustang Mach-E vehicles built on or before 07-Jul-2021 may exhibit an illuminated malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P061A, P1A1E and/or P2533. This may be due to the parameters in the powertrain control module (PCM). To correct the condition, follow the Service Procedure to reprogram various modules starting with the PCM. Action: Follow the Service Procedure steps to correct the condition if the vehicle meets all of the following criteria:
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Emissions Warranty/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/Emissions Warranty/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. Labor Times
1. Connect a battery charger to the 12-volt battery. NOTE: To prevent the battery saver mode from activating on the vehicle, make sure the negative cable of the charger is installed on a chassis or engine ground, and not the 12-volt battery negative terminal. Do not have the vehicle plugged into the high voltage battery charger during programming. This can cause incorrect module programming. Make sure only the 12-volt battery charger is installed. 2. Reprogram the PCM using the latest software level of the appropriate Ford diagnostic scan tool. 3. Check the availability of software updates on the following modules and update as required: (1). Secondary on-board diagnostic control module (SOBDM) (2). Battery energy control module (BECM) (3). Secondary on-board diagnostic control module B (SOBDMB) (4). Secondary on-board diagnostic control module C (SOBDMC) (5). Anti-lock brake system (ABS) module NOTE: Only one module may be updated at a time. |
Similar to 21-2245 but different issue. Still both TSBs are about PCM updates.
