breeves002
- Sam
- Feb 21, 2021
- St. Louis, MO
- 2021 Mach-E GT PE
For some reason Ford is being weird and not letting me print it out so I just am attaching screenshots as well as the normal copy+paste.
This is NOT the recall for the roof/windshield reseal. This is separate.
Glass Roof - Wind Noise From Upper Windshield Area Above 45 MPH (72 Km/H) - Built On Or Before 15-Feb-2021
Model:
Issue: Some 2021 Mustang Mach-E vehicles built on or before 15-Feb-2021 may exhibit a wind noise turbulence noise at the top of the windshield when traveling above 45 mph (72 km/h). This may be due to the underflush condition of the windshield to glass roof at the top header area being greater than maximum spec of 4.4 mm. To correct the condition, follow the Service Procedure to install the weather strip/moulding.
Action: Follow the Service Procedure steps to correct the condition on vehicles that meet all of the following criteria:
Parts
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Repair/Claim Coding
Service Procedure
1. Using compressed air, lightly blow out the channel between the roof glass and the windshield to remove any dirt or debris.
2. Using isopropyl alcohol and a clean cloth, clean and dry the channel between the roof glass and the windshield.
NOTE: The B side of the windshield must be clean to ensure proper adhesion. (Figure 1)
Figure 1
3. Starting at one edge of the roof glass, peel back approximately 4 inches (10 cm) of the protective cover on the sticky edge of the moulding and insert into the channel. (Figures 2-3)
Figure 2
Figure 3
NOTE: A 90 degree pick or hook tool can help seat the strip to the vehicle moulding. Insert between the roof and the new moulding. (Figure 4)
Figure 4
4. Once the first end is started, continue to seat the moulding across the windshield to the opposite edge of the roof glass, pealing the protective cover while installing. (Figure 5)
(1). Click here for an example.
Figure 5
NOTE: Make sure there is no misalignment, waves, exposed tape, or protrusion above the roof moulding.
5. Using a knife/razor, cut the moulding at the other end of the roof glass. (Figures 6-7)
Figure 6
Figure 7
Model:
Ford 2021 Mustang Mach-E |
• 2021 Mustang Mach-E
• Equipped with a glass roof
• Built on or before 15-Feb-2021
• Wind noise from the upper windshield area when traveling above 45 mph (72 km/h)
Parts
Service Part Number | Quantity | Description |
LJ8Z-5803136-A | 1 | Windshield Weatherstrip |
Labor Times
Description | Operation No. | Time |
2021 Mustang Mach-E: Install Moulding Following The Service Procedure (Do Not Use With Any Other Labor Operations) | 212369A | 0.3 Hrs. |
Causal Part: | 5803136 |
Condition Code: | 07 |
Service Procedure
Figure 1
Figure 2
Figure 3
Figure 4
Figure 5
Figure 6
Figure 7
