TSB 21-2405 Illuminated Powertrain Malfunction (Wrench) Indicator - Various Diagnostic Trouble Codes (DTC) - Built On Or Before 09-Sep-2021
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
This is the GSM TSB we saw in Europe but they have now released it here.
TECHNICAL SERVICE BULLETIN
21-2405
16 November 2021​
Model:
Ford
2021 Mustang Mach-E
Issue: Some 2021 Mustang Mach-E vehicles built on or before 09-Sep-2021 may exhibit an illuminated powertrain malfunction (wrench) indicator and/or display the message Shift System Fault – Service required with DTC U0103:87 stored in the secondary on board diagnostic module (SOBDMC). Some vehicles may also exhibit DTCs U0100:00, U0121, U0140, and/or U0155 stored in the gear shift module (GSM). This may be due to the software in the GSM. To correct the condition, follow the Service Procedure to reprogram the GSM.
Action: Follow the Service Procedure steps to correct the condition on vehicles that meet all of the following criteria:
• 2021 Mustang Mach-E
• Built on or before 09-Sep-2021
• Illuminated powertrain malfunction (wrench) indicator and/or display the message Shift System Fault with DTC U0103:87
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2021 Mustang Mach-E: Retrieve DTCs And Reprogram The GSM (Do Not Use With Any Other Labor Operations)
212405A​
0.4 Hrs.​
Repair/Claim Coding
Causal Part:RECAL
Condition Code:04
Service Procedure
1. Reprogram the GSM using the latest software level of the Ford Diagnosis and Repair System (FDRS) scan tool.
fmcgirt
Frank
nm
Premium Mach E
21-2405
16 November 2021​
Model:
Ford
2021 Mustang Mach-E
Labor Times
212405A​
0.4 Hrs.​
Repair/Claim Coding
Causal Part:RECAL
Condition Code:04
Service Procedure
Thanks for posting this. After 7 months and 1125 miles of completely trouble free operation this sw bug got us. I seems that OTA 1.7.1 two days ago may have triggered it. The first time I started our MachE 4X Premium Extended Battery after the update I got the "Service Soon" message with the yellow wench. Also got a FordPass message that "A Powertrain or AWD fault had been detected, contact your dealer as soon as possible. So after a couple of trys at turning off and on, letting it sit for awhile and trying it again, I went to the dealer. The messages lasted long enough for him to take pics of them but the first time he turned the car off and then later back on, all messages disappeared and all appeared normal. Glad we had those pics!
I had been feeling rather smug about this car with all the problems others have had and since I had bought a second fob and did not implement PAAK upon delivery. Now I am thinking of disabling the Automatic Software Update Option, at least until Ford gets its act together, maybe about a year from now if we are lucky.
Tyldum
Norway
Mustang Mach E First Edition
I had this (in Europe). No drama, car works fine.
An hour in the shop to fix to get rid of the message.
The DTC says PCM lost connection with the GSM. I cleared DTC with carscanner for Android, but didn't help.
fmcgirt
Frank
nm
Premium Mach E
It would be really nice if the Ford Software Developers would/could initiate a complete system self test OTA after an update like 1.7.1 was installed and then clean up any errors it caused. Do this instead of the having the car owners or service depts have to go through doing this. Even better do this before releasing the update. There are many reports on this forum of problems that 1.7.1 has caused, both directly and indirectly. It is very good that these people are not developing critical medical software.
breeves002
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
Well…it is supposed to. The problem is there are edge cases that Ford didn’t plan for or foresee. Which is the biggest problem. It’s different testing something versus all of the real world variables. Sure they probably should have been able to avoid a lot of it but this is new for Ford and let’s be real they just aren’t very good at it.
fmcgirt
Frank
nm
Premium Mach E
I don't think all of this should be so new for Ford. Some of it happened with the newly redesigned Explorer around 2007-2008 when they first went with Sync. Two of my neighbors each bought one and you could hear them complaining half a block away - with many of the same complaints we are making today - and with Ford dealers trying to cope. Writing, debugging, testing, delivering, and maintaining control software and firmware is extremely hard and if you don't commit to that as a company the current situation will continue.
These are among the reasons OTA rollout has been slower than hoped.
breeves002
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
Its why they have 8 open positions for OTA engineers lol. They didn't think ahead very well.
Blue highway
Oregon
Mach E Premium SR RWD
Based on reading a few TSBs I have long term hope Ford will sort these things out in the next 12 months… the reason is that the TSBs apply to both the MME and Lightning. A lot of the modules are the same. The F150 lightning will have whatever resources are needed to get this right… Come to think of it, the MME is a bit of a shakedown for the Lightning.
KevinS
Job 1 2021 Mach-E (SR AWD)
Where can I get a copy of the TSB? I'm compiling a binder copy of all the items. The NHTSA repository is way behind.
Gimme_my_MME
Dearborn
Ok I'm curious, why are you making a binder of all the TSB's?
evmass
MA
2021 Silver Mach E Select
Did you get this binder created? I'm looking to do the same thing.
KevinS
I did, but haven't updated it with SSMs or TSBs since then. But it is a nice place for me to keep my recall service receipts, etc. as well.
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
Three days short of a year with the car and today upon start up I got the Service Vehicle Soon message along with Powertrain Malfunction error in Fordpass. We took it in to our local Ford dealer and they applied a GSM update per TSB 21-2405.
