breeves002
- Sam
- Feb 21, 2021
- St. Louis, MO
- 2021 Mach-E GT PE
This appears to be why we've seen a PCM update pop up.
TECHNICAL SERVICE BULLETIN Illuminated MIL With DTC P0D2A | 22-2034 09 February 2022 | |||||||||||
Model:
Issue: Some 2021 Mustang Mach-E vehicles may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P0D2A. This may be due to the parameters in the powertrain control module (PCM). To correct the condition, follow the Service Procedure to reprogram various modules starting with the PCM. Action: Follow the Service Procedure steps to correct the condition on vehicles that meet all of the following criteria:
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Emissions Warranty/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/Emissions Warranty/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. Labor Times
1. Connect a battery charger to the 12-volt battery. NOTE: To prevent the battery saver mode from activating on the vehicle, make sure the negative cable of the charger is installed on a chassis or engine ground, and not the 12-volt battery negative terminal. Do not have the vehicle plugged into the high voltage battery charger during programming. This can cause incorrect module programming. Make sure only the 12-volt battery charger is installed. 2. Reprogram the PCM using the latest software level of the Ford Diagnosis and Repair System (FDRS) scan tool. 3. Check the availability of software updates on the following modules and update as required:
