- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Damaged wiring near the parking brake connectors can cause this error. It may be intermittent.
EDIT: CSP 22P31 has been released for this issue.
TECHNICAL SERVICE BULLETIN 22-2143
Parking Brake Fault Service Now Message In IPC - DTCs C2008, C2007,C1034, U0293 And/Or U0100 - Built On Or Before 15-Mar-2022
Issue: Some 2021-2022 Mustang Mach-E vehicles built on or before 15-Mar-2022 may exhibit a Parking Brake Fault Service Now message in the instrument panel cluster (IPC) and DTCs C2007, C2008, C1034, U0293 and/or U0100 in the anti-lock brake system (ABS) module. This may be due to an open/corroded circuit near the rear brake caliper. To correct the condition, follow the Service Procedure to replace the electronic parking brake (EPB) connector.
Action: Follow the Service Procedure steps to repair vehicles that meet all of the following criteria:
Involves replacement of the electric parking brake connectors at the wheels, see PDF.
Service Procedure:ā¢ 2021-2022 Mustang Mach-E
ā¢ Built on or before 15-Mar-2022
ā¢ At least one of the following:
- Parking Brake Fault Service Now message in the IPC
- DTCs C2007, C2008, C1034, U0293 and/or U0100
