- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Nov 2022 Update: This TSB is now replaced with TSB 22-2404.
This bulletin supersedes TSB 22-2117 (the fix for stuck power-up 1.7.1 update). Please ask your dealer to use the new procedure. Your dealer needs to update their FDRS software (new version today), disable antivirus protection, use the specified adapters that are verified to work by Ford, and connect a battery charger during the update. If they don't do all of these, the procedure will likely fail.
TECHNICAL SERVICE BULLETIN 22-2150 13 April 2022
Unable To Update The APIM Or TCU With The FDRS And USB Drive - Module Recovery
This bulletin supersedes 22-2117.
Models:
2021 Bronco
2021 Edge
2021 F-150
2021 Mustang Mach-E
2021 Nautilus
Summary
This article supersedes TSB 22-2117 to update the Issue, Action, Service Procedure.
Issue: For some 2021 Mustang Mach-E, F-150, Edge, Nautilus and Bronco vehicles technicians may experience the inability to update the accessory protocol interface module (APIM) or telematics control unit (TCU) using the Ford Diagnosis and Repair System (FDRS) and Universal Serial Bus (USB) drive. The PTS – OTA Dashboard on vehicles with this condition may also display multiple APIM and/or TCU updates have failed, and/or a no OTA history message. In addition, on vehicles with this condition, the customer may have reported experiencing a Ford Power-Up software update failure message via the vehicle display and/or FordPass/LincolnWay. This may be due to an internal software error. To correct this condition, follow the Service Procedure to update and/or recover the APIM/TCU.
NOTE: Only 10% of vehicles may require this procedure.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• 2021 Mustang Mach-E/F-150/Edge/Nautilus/Bronco
• Inability to update the APIM and/or TCU using the FDRS and USB drive
Special Tool(s)
USB-to-Ethernet adapter: Trendnet TU2-ET100 USB2.0, Trendnet TU3-ETG USB 3.0, Startech USB31000S USB 3.0, UGREEN USB USB 3.0 model no 40321, Amazon Basics USB 3.0 U3-GE-1P. These adapters have been validated through Ford service testing.
Mini B 5 Pin Female Adapter: Rotunda Part# CCMUSB-AF-BF5 or equivalent (Vehicles with USB Media Hub)
USB 2 Cable - Male to Male: Rotunda Part# CCMUSB2-AM-AM-10 or equivalent (All vehicles)
Ethernet cable assembly, obtain locally (All vehicles)
NOTE: Ford has received feedback from technicians that the following USB-to-Ethernet adapters do not work and should not be used: TP-Link USB3 - 10/100/1000, Cable Creations 10/100/1000 USB3, UGREEN USB2 - 10/100, Cable Leader USB 2.0, UGREEN ‎FBA_20256. In the near future, a list of good/bad USB-to-Ethernet adapters will be published on PTS > Service Tips.
Service Procedure
NOTE: Administrative access on the laptop computer being used is required to perform this procedure. Make sure any antivirus software loaded in the laptop computer is disabled or uninstalled prior to performing this procedure.
NOTE: Use only a wireless connection for internet access as this application requires the use of the laptop computer ethernet port during the module recovery procedure. Verify the FDRS is at the latest software level.
See attached PDF for full procedue and pictures:
Models:
2021 Bronco
2021 Edge
2021 F-150
2021 Mustang Mach-E
2021 Nautilus
Summary
Special Tool(s)
Service Procedure
