Not really. If you are dealing with limited information, near zero idea what the majority of the software getting pushed through is doing, unclear specs from hardware due to NDA or simply because they have only one customer with that design...it's rare you'll have a definite root cause since so much of the car is a black box. You start with symptoms, classify similar symptoms to see if they could be related, then you trace that back to a root cause if possible. Someone like me that has zero time to look into this stuff browses this forum and maybe a few other sites and sees 12v issues reported everywhere from devices not turning off to bad batteries (what from something not turning off or some weird bad core or bad BECM software?). I'm sorry but a 12v battery shouldn't be dying with half a dozen other problems with the car. That's a bad design. You can't even get into the damn car without a 12v...it's a really bad design. The 12v should be protected better than this just like if you're expecting your clients to park their cars in a rat infested sewer maybe the wires should be better protected than they are?Okay ... well you and I must have vastly different ways of thinking.
Here’s a rag for that word vomit.Not really. If you are dealing with limited information, near zero idea what the majority of the software getting pushed through is doing, unclear specs from hardware due to NDA or simply because they have only one customer with that design...it's rare you'll have a definite root cause since so much of the car is a black box. You start with symptoms, classify similar symptoms to see if they could be related, then you trace that back to a root cause if possible. Someone like me that has zero time to look into this stuff browses this forum and maybe a few other sites and sees 12v issues reported everywhere from devices not turning off to bad batteries (what from something not turning off or some weird bad core or bad BECM software?). I'm sorry but a 12v battery shouldn't be dying with half a dozen other problems with the car. That's a bad design. You can't even get into the damn car without a 12v...it's a really bad design. The 12v should be protected better than this just like if you're expecting your clients to park their cars in a rat infested sewer maybe the wires should be better protected than they are?
My mistake though if you haven't been seeing it I guess it isn't an issue...just looks really weird to me...even more so when you see customers buy 12v battery monitors for a car that has barely been on the road for a year.
Its a recall. That has nothing to do with warranty. I kept receiving recall notifications for my 2009 G8 until I sold it earlier this year. I never went in for the "fixes". I know someone who did and he had to pay nothing.What if my HVBJB fails after the warranty period? Will I have to pay for the replacement even though Ford has admitted to having a design flaw?
There is no current recall for replacing the hardware.Its a recall. That has nothing to do with warranty. I kept receiving recall notifications for my 2009 G8 until I sold it earlier this year. I never went in for the "fixes". I know someone who did and he had to pay nothing.
I think you're misinterpreting what this is, it's a service bulletin meant for dealer service technicians when a fault in the hardware is detected. It doesn't change anything, Ford was replacing bad parts before this TSB and they will continue to replace them as they fail. This bulletin just summarizes what to repair to make it easier to look up. Replacement is not being encouraged any more than before, your hardware must fail before it is replaced.This is the first I think I am seeing officially or formally that hardware replacement is now being encouraged. I think this is a step in the right direction. The part that still sucks as a customer, is having it fail and strand you before you can finally get the part that hopefully restores reliability with the car. It really feels like this should just be done proactively to prevent the frustration, aggravation, and agitation customers will inevitably feel when it happens to them. Especially since everything else about the process needs refinement and improvement.
Call the service departments in your area and find out which one has earliest availability. They are able to install the software update associated with the recall as of about a month ago.Yeah, unfortunately, there are going to be a lot of people, like me, that are going to have the hardware fail well before the software update ever gets applied. And even when it does eventually get applied, it doesn't undo the damage already done to the part. So stranding is likely still going to happen.
It took having my car fail, before I could get all the updates for the car. And sure, that helps going forward for THIS issue, What happens when the next major update needs to happen to prevent an issue, and it takes forever to get that one as well?Call the service departments in your area and find out which one has earliest availability. They are able to install this update as of about a month ago.
It isn't taking forever for dealers to get these updates. Not this one. Not previous ones. You just need to schedule a service visit.It took having my car fail, before I could get all the updates for the car. And sure, that helps going forward for THIS issue, What happens when the next major update needs to happen to prevent an issue, and it takes forever to get that one as well?
Why even bother with OTA at all if they can't do them in a timely manner? Just kill OTA and have all updates be dealership updates at that point. The minute an update this critical and serious was available, it should have been pushed out to cars immediately. Not, having to beg and plea with a dealer to apply. Also where is the proactivity from dealers, reaching out to customers that bought Mach Es and scheduling it as a courtesy to make sure it has been done? Why am I having to hound them to make it happen?It isn't taking forever for dealers to get these updates. Not this one. Not previous ones. You just need to schedule a service visit.
Seems like the OTA for this update is going out to drivers as of last night. Get that applied and it lowers the chances of being stranded IF your contactors weld/fail.It took having my car fail, before I could get all the updates for the car. And sure, that helps going forward for THIS issue, What happens when the next major update needs to happen to prevent an issue, and it takes forever to get that one as well?
Ok... I finally went and skimmed through your post history. I think I'm mostly caught up now.Why even bother with OTA at all if they can't do them in a timely manner? Just kill OTA and have all updates be dealership updates at that point. The minute an update this critical and serious was available, ti should have been pushed out to cars immediately. Not, having to beg and plea with a dealer to apply.
or a 3rd option, as in my case, of sitting at two different dealers and then opening a Ford case that went nowhere, to deal with the two dealers not doing any updates yet charging Ford for them anyway, and then not being able to get the recall update at all. well,still waiting to see if OTA comes and installs it or not after this fiasco.So for you and most of us, it's a choice of two 'evils.' The waiting period for the OTA update, or the time spent communicating with a dealer and sitting in their lobby while they update the vehicle.
