- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
We have an updated TSB for fixing issues getting USB updates to work when updating with FDRS. This bulletin supersedes TSB 22-2150 (AKA the fix for stuck Power-Up 1.7.1 update). The TSB now mentions the possibility of stuck GWM USB update being caused by this issue as well (in addition to APIM and TCU). There are also additional warnings related to the APIM being permanently locked out when this procedure is used incorrectly, and a couple of additional figures showing how the USB adapters should be connected together. The previous TSB also showed the wrong trim panel being removed from the F150.
I want to emphasize Module Update Repair in FDRS should be used with caution. Both @Mike G and myself have seen dozens of vehicles where dealers ran Module Update Repair unsuccessfully and ended up permanently locking the APIM (SYNC) module so that it can never be updated again. In most cases, it seems they tried to run the procedure without having the required USB adapters connected, or ran it too many times. There is a 20-day countdown timer that starts the first time Module Update Repair is run (see bold blue caution statement below). If the procedure is not completed successfully in that initial 20-day window, or run more than 15 times, the APIM will be permanently locked, and the only way to fix it is to completely replace the APIM. Because so many dealers have accidentally "bricked" APIMs running this procedure unsuccessfully, APIMs are currently on a multiple-month backorder.
TECHNICAL SERVICE BULLETIN 22-2404 31 October 2022
Unable To Update The APIM, TCU Or GWM With The FDRS And USB Drive - Module Recovery
This bulletin supersedes 22-2150.
Models:
2021 Bronco
2021 Edge
2021 F-150
2021 Mustang Mach-E
2021 Nautilus
Summary
This article supersedes TSB 22-2150 to update the Service Procedure.
Issue: For some 2021 Mustang Mach-E, F-150, Edge, Nautilus and Bronco vehicles technicians may experience the inability to update the accessory protocol interface module (APIM), telematics control unit (TCU) or gateway module (GWM) using the Ford Diagnosis and Repair System (FDRS) and Universal Serial Bus (USB) drive. The PTS – OTA Dashboard on vehicles with this condition may also display multiple APIM and/or TCU updates have failed, and/or a no OTA history message. In addition, on vehicles with this condition, the customer may have reported experiencing a Ford Power-Up software update failure message via the vehicle display and/or FordPass/LincolnWay. This may be due to an internal software error. To correct this condition, follow the Service Procedure to update and/or recover the APIM/TCU.
NOTE: Only 10% of vehicles may require this procedure.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• 2021 Mustang Mach-E/F-150/Edge/Nautilus/Bronco
• Inability to update the APIM, TCU or GWM using the FDRS and USB drive
Special Tool(s)
USB-to-Ethernet adapter: Trendnet TU2-ET100 USB2.0, Trendnet TU3-ETG USB 3.0, Startech USB31000S USB 3.0, UGREEN USB USB 3.0 model no 40321, Amazon Basics USB 3.0 U3-GE-1P. These adapters have been validated through Ford service testing.
Mini B 5 Pin Female Adapter: Rotunda Part# CCMUSB-AF-BF5 or equivalent (Vehicles with USB Media Hub)
USB 2 Cable - Male to Male: Rotunda Part# CCMUSB2-AM-AM-10 or equivalent (All vehicles)
Ethernet cable assembly, obtain locally (All vehicles)
NOTE: Ford has received feedback from technicians that the following USB-to-Ethernet adapters do not work and should not be used: TP-Link USB3 - 10/100/1000, Cable Creations 10/100/1000 USB3, UGREEN USB2 - 10/100, Cable Leader USB 2.0, UGREEN FBA_20256. In the near future, a list of good/bad USB-to-Ethernet adapters will be published on PTS > Service Tips.
Service Procedure
CAUTION: Due to Ford cyber security requirements, the module repair procedure outlined in this article is limited to a maximum of 15 attempts with a total of 20 days from the first time the application is run before the application is permanently disabled for each unique VIN. Make sure that all required and compatible tooling listed in this article is available prior to performing this procedure to reduce the chances of encountering this lockout state. If a lockout occurs, module replacement may be necessary. Note that even if the application is run successfully, the 20 day timer (allowing 15 attempts) continue to run in the background. If the module repair application has successfully completed in the past, it is not required to be run again.
NOTE: Administrative access on the laptop computer being used is required to perform this procedure. Make sure any antivirus software loaded in the laptop computer is disabled or uninstalled prior to performing this procedure.
NOTE: Use only a wireless connection for internet access as this application requires the use of the laptop computer ethernet port during the module recovery procedure. Verify the FDRS is at the latest software level.
See attached PDF for full procedue and pictures:
Models:
2021 Bronco
2021 Edge
2021 F-150
2021 Mustang Mach-E
2021 Nautilus
Summary
Special Tool(s)
Service Procedure
