The TSB for the "1 Pedal Drive Fault - Press Brake Pedal To Reduce Speed" warning message has been released. If you get this warning message, you can ask your dealer to update the powertrain software with this TSB.
TECHNICAL SERVICE BULLETIN
"1 Pedal Drive Fault - Press Brake Pedal To Reduce Speed" Warning Message Displayed In The IPC With DTC P0C2F:92 Stored In The SOBDMC
24-2187
07 June 2024​
Model:
Ford
2021-2023 Mustang Mach-E
Markets: North American market only
Issue: Some 2021-2023 Mustang Mach-E vehicles may exhibit a "1 Pedal Drive Fault - Press Brake Pedal To Reduce Speed" warning message displayed in the IPC. The customer may also notice that the 1 Pedal Drive feature has been deactivated. A DTC P0C2F:92 may also be stored in the SOBDMC. This concern may also be present when one pedal drive mode is enabled. This may be due to the SOBDMC. To correct the condition, follow the Service Procedure to reprogram the powertrain modules using the latest level of the FDRS.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• 2021-2023 Mustang Mach-E
• "1 Pedal Drive Fault - Press Brake Pedal To Reduce Speed" warning message displayed in the IPC
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Service Part New Vehicle (SPNV)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SPNV/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2021-2023 Mustang Mach-E: Reprogram The Appropriate Modules As Required By The Software Update And Service Procedure (Do Not Use With Any Other Labor Operations)
MT242187​
Actual Time​
Repair/Claim Coding
Causal Part:7B012
Condition Code:04
Service Instruction
1. Connect a battery charger to the 12-volt battery.
NOTE: To prevent the battery saver mode from activating on the vehicle, make sure the negative cable of the charger is installed on a chassis or engine ground, and not the 12-volt battery negative terminal. Do not have the vehicle plugged into the high voltage battery charger during programming. This can cause incorrect module programming. Make sure only the 12-volt battery charger is installed.
2. Reprogram the PCM using the latest software level of the FDRS scan tool.
3. Check the availability of software updates on the following modules and update as required:
• SOBDM
• BECM
• SOBDMB
• SOBDMC
• ABS module
NOTE: Only one module may be updated at a time.
Spacey
UK
Mustang Mach E
The TSB says North American market only, so does it mean that UK users are not affected or is this a silly question as the UK does seem to run a different set of OTA's compared to NA? 🤔
alexgorod
Alex
DBA
When the dealer updates these modules, will it apply any of the existing OTAs as well?
OTA updates are never applied by dealers, it's not possible. They update modules. In the process of updating modules, they may negate an OTA update, or parts of it.
alexgorod
Alex
DBA
Right, that's what I meant - if any of recent OTAs have the same module software updates that are included in this TSB.
2FlyMache
Patrick
Martinez GA
2021 Rapid Red Ex4 MachE
Just got my recall completed and no issues with 1pedal
MarkP213
Mach E 4X Premium, Infinite Blue
Same here, last month. Zero issues. I wonder if the dealers installed the fix during our recalls, or just lucky and haven’t had the problem?
Teslaeata
Here
Red one
I wouldn’t worry about it, there will be differences in the software across different market areas and if some commonality does exist which means our UK beasts are affected I am sure we will hear officially 👍
Jerrytball
Jerry
Gulfport MS
2023 Ford Mach E GT
24-2187
07 June 2024​
Model:
Ford
Labor Times
MT242187​
Actual Time​
Repair/Claim Coding
Causal Part:7B012
Condition Code:04
Service Instruction
After I saw this, I made sure my service guy had this so I emailed it to him and while they got the car, they’re going to verify this is not an issue as well as replacing the RFA that just came in today. Hopefully I’ll have the car back by Tomorrow.
Fixbear
Frank
ADK. foothills, NY
Your motor vehicle rules are different from NA. So they program different country to country.
Just Lurking
Paul
Washington
2022 Mach-E GT
Great stuff; thanks Lee. Do you happen to know whether this update is expected to go out OTA? I'm experiencing this issue and it's annoying but if an OTA is expected this month I may just wait for it.
Thanks!
Thanks!
There is no mention of an OTA, so if you have this issue you need to make a dealer visit.
Logal727
C
Pretty sure this was part of the software updates they did if you got recall done within last month or so, after the big 23S56 pause.
Motomax
Max
VW GLI, 4Runner
Kinda crappy that they did the fix as a TSB. My dealership won’t do TSBs out of warranty. Now I have to work with ford corporate to get them to fix an issue they caused with a recall…
