Two Missing Cargo Anchor Points / Tie downs
Bukaye71
Scott
Walnut Creek, CA
2021 Ford Mach-E FE RR
My MME FE RR is the bottom photo that is missing two of the anchor points in the rear cargo area. There are impressions in the carpeting for them but none there when I received the vehicle. The two other anchor points are just inside the rear hatch. The first photo shows that they should come with the vehicle, and the online owners manual references it too. Did your MME come with theses two anchor points or are they missing too?
with anchor points
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Not sure either of mine have any anchor points there either. I’d have to check when I get home tomorrow. Maybe this is right up there with the screw in tow hook that we have a space for.
Marcel
The Netherlands
Woodworker
with anchor points
Maybe not the best, but I see 5 anchor points, these are not good enough?
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
ncmagus
Montréal, Qc, Canada
Mach e Select, AWD
Same for me, only two anchor near the door.
I did thought of using those in the seat, but they are not as well positioned in my opinion to keep things from moving.
Bukaye71
Scott
Walnut Creek, CA
Anyone else missing the rear cargo anchor points closer to the back of the rear seats. The latch anchor points on the back of the rear seat are for child safety seats and are too high to be off any use for a cargo net, storage bag, etc.
with anchor points
The Mach E doesn't have anchor points there. The only two rear anchor points are higher and near the door.
Behoff
Middle Grove, NY
2021 Mustang Mach-E
I am in the same situation -only two anchor points right at the bottom of the lift gate. So I ask you, how useful are two anchor points right below the liftgate?
The manual shows four anchor points. I could use the baby seat anchors behind the rear seats, but what about when I have the seats folded down? What about when I have - hmm - baby seats occupying those spots!!!
When I went to the dealer, they just shrugged. Said my VIN didn’t include them. WTF??
i Know it seems like a minor thing, but it is pissing me off.
AlpaChino
JB
Indiana
Mach-e Premium eAWD Ext Range, Rapid Red
Thank You. I’ll be ordering two today. Just in case.
Were you able to confirm of the threaded hole required for these exists on our stateside MMEs? Did you order these?
The hole in the metal bumper bar is there but the nut that receives the tow hook is not welded to the back side of the bumper. ??
