Gullwingdmc
Chip
Boston, MA
That is not a bad idea.... To have some type of black plastic cover to hide everything across the back of the console (wire from the pad and the USB ports). I have the pad plugged into the USB-C port and the only time I use the USB-A port is when a module in FDRS requires a USB update.
Ya I’m thinking you have a flexible piece of rubber where it meets the pad to allow you to plug the cable in and then a piece of molded plastic that comes up and covers the USB port. You could even make a hole in that molded plastic for the USB A port.
markboris
Sonora, CA
_______ '20 Shelby GT500 FPB '24 Mach-E GT GG
Maybe someone on here can make something like this with one of those fancy 3D printers which is something I do not have. Maybe I can ask Zac over at AOSK if he can come up with something.
Gullwingdmc
Chip
Boston, MA
Yeah the wiring would be the tricky part though. I’ve seen other products that have smaller wiring though, so it’s definitely possible.
sockmeister
Pennsylvania
2023 Mach-E GTPE
SW Engineer
This is a great idea, but the price is a bit up there. Can anyone vouch that they're getting at least 15W of charging out of it? (Using an app like ampere or similar)
FarSide
Fairfield, CT
Jaguar F-Type '70 Vet, Outback Onyx, '04 Wrangler
Best upgrade for the MME, especially since my stock charging mat was just slightly more effective than that joke rear storage cover.
KidGalahad
Oklahoma
2023 Ford Mustang Mach-E Premium
Intriguing idea, but the visible cable and that block on the cable kills it for me. If they came up with a more elegant cable solution, I'd probably buy it.
markboris
Sonora, CA
This is why I did not buy one months ago but after installing the updated version last month, I hardly notice the cable and little box now. Normally it is quite dark in that area. The photo below shows more light on the little box and cable than there normally is. It's just the way the camera took the photo and some reflections in the gloss black plastic console trim makes things look a little distorted with the lighting but it's really not all that bad.
Ford Mustang Mach-E TWRAPS Dual MagSafe Wireless Charger for center console IMG_8890D
stealthytolkien
P
Ford Mustang Mach E GT Performance
This does something else so well that I really feel like the money was well spent. The original Mach E pad is trash.
I place my iPhone pro max and right next to it my AirPods Pro 2. The strong magnet makes this setup looks like the product is designed for it. No more trying to look for my AirPods and they’re firmly resting on the pad charging. And looks cool :) oh and the cable is barely visible. I am able to charge two devices and use my music USB stick in the second USB port on the car right under it so there’s enough current for everything.
josephyancey
Joseph
Arkansas
2021 Mach E CR1 (Job 1)
I helped with the one that Twraps makes for the accord hybrid and tested the different charge puck options. The older one (without the waves) does a more traditional wireless charge. The new one shows up on iphone as a magsafe charger so you get a fancy charging animation. Other than that, they behave the same. Both are able to charge apple headphones. I did not have a way to test charging amperage but both do a decent job charging while also using wireless carplay.
Gullwingdmc
Chip
Boston, MA
This is a newer version. There is a single cable that comes out
Is there a picture of what the new version looks like?
That’s the only thing holding me back from buying one. Once they get rid of that box I’ll be the first to buy one.
Neil4Real
@markboris posted it above and the one on their website/Amazon shows the latest.
I've had the original for over a year now and was very hestitant for the same reason. I thought my driving position would show the block but all I can barely see is the cable if I look for it. It really is amazing. It can actually charge my phone while using CarPlay! Before, my phone would get crazy hot and/or my phone would stay at the same charge level. Plus, it just makes the phone way more stable when you're having fun xD
Gullwingdmc
Chip
Boston, MA
That’s what I was afraid of. I won’t buy it until that box is gone. I can clearly see the USB port with my driving position, so I will see that ugly cable. I can get over something being plugged in, but that box is a dealbreaker.
It’s too bad, because I get the benefits you mentioned, but I am a form over function person. I also don’t have many issue with the built in charger. Granted I have the new design that’s at an angle.
apwelsh
Armand
Riverside, CA
2023 Mustang Mach-e Standard
Programmer
A much better solution to the wireless charging that is supplied.
I would buy one if it didn’t use the USB port and instead simple replaced. The built-in Qi charger
Fins160
JP
Tempe, AZ
2022 MachE Select C/T Dark Matter Gray
Created a pricewatch on camelcamelcamel, will snag it if it drops!
Nerwyn
Nerwyn
North Carolina
2021Ford MME Premium RWD
I ordered one a few days ago along with a magsafe case for my Pixel Fold. Hopefully I'll be able to use wireless Android Auto now without losing charge.
