Socalsp3
I thought that I read recently on this forum that a Ford Engineer said that it's not good to regularly charge to 100%. Something about nowhere for the electrons for go when fully charged and using brake regen. 90% is the most you should charge when not on a long trip.
Yes, regen is limited at 100% so mechanical brakes will be used instead (energy lost to heat). This is correct advice, only charge above 90% right before leaving on a long trip where you need the range. You shouldn't charge to 100% for daily use.
i thought what the engineer said was weird. unless you are starting your trip going down a hill you will use more electricity moving the car than gain from regen
