Unusual rotor wear...
rzanzerkia
Robert
New Hampshire
2013 Acura TL, 2016 MB GLE350, 2021 Mach-e Premium
My wife's MachE has only 1200 miles and less than 3 months old.
One right rear rotor has scrape marks.
There is another rotor with much less markings and two without any wear.
No noise or performance issue but I wonder if break pad is wearing uneven on the rotor with heavy markings.
I can take it to the dealer but they are not very good (no loaner, last time kept the car for 2 days and nothing for headlight issue, still no replacement part)
Anyone have seen this on their car?
Does it needs to be checked by the dealer?
Ford Mustang Mach-E Unusual rotor wear... WhatsApp Image 2022-04-04 at 6.38.48 PM (3)
Ford Mustang Mach-E Unusual rotor wear... WhatsApp Image 2022-04-04 at 6.38.48 PM (2)
Ford Mustang Mach-E Unusual rotor wear... WhatsApp Image 2022-04-04 at 6.38.48 PM (1)
Third image has most markings, fourth has some..
First 2 shows no wear...
Thanks
heisnuts
Darrel
Oregon
Model 3 Performance
Have you tried a few hard stops from freeway type speeds (with no one behind you of course)? It almost looks like the moisture/dirt build up on the rotors is not being completely cleared off since with EV's most braking is regen braking so the pads are not rubbing on the rotors to clean everything off.
That Right Rear rotor looks horrible to me. Can you feel the grooves with your fingernail? I think that should be checked out. That Left Rear doesn't look much better.....
For comparison.
Here are photos taken last week. Over 33k miles on the vehicle so far....
Ford Mustang Mach-E Unusual rotor wear... 20220329_162917
Ford Mustang Mach-E Unusual rotor wear... 20220329_162924
rzanzerkia
rzanzerkia
Robert
New Hampshire
True we use 1PD all the time.
I will try to use break little more to see if it gets more even.
hawkeye3point1
NH
Thanks
Yes, my rear rotors look the same, fronts are fine, @ 2k+ mi., and I regularly exercise them by braking in neutral.
I called the dealer and was told to brake hard occasionally, but I do not think that will reverse the scoring. Will probably end up taking it in to be checked within a month, and hopefully get some FDRS updates applied.
rzanzerkia
rzanzerkia
Robert
New Hampshire
For comparison.
Yes that's what I would expect at 1200 miles.
Wife drives very short distance but car does get used every day.
I ran my finger and it's gouge marks.
This is not normal.
Going to call the dealer.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
I would take it out run up to speed, shift to neutral, then brake. Do this a few times to polish the rust off the rotors…. Then see if there are actual grooves or if what you seeing is just surface rust from brake rotors that aren't really being utilized.
Thanks
Mine look exactly the same.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Ford Mustang Mach-E Unusual rotor wear... F125A40D-63B3-41E8-9D90-A8F1E2D48C7B
I took the above photo this morning before driving to work. It caught my eye as unusually heavy rust as the car had been sitting for 5 days.
Ford Mustang Mach-E Unusual rotor wear... 7D3C32C0-A0EF-4D7C-8D07-AAC764CD5C22
This is the same rotor after driving to work without doing anything to clean the rotors.
Ford Mustang Mach-E Unusual rotor wear... 8A0E14F4-AB1C-47DA-A566-996D8361DEA4
Then same rotor after a couple cleaning stops in neutral here in the parking lot here at work.
I sure hope you don't break more.... Try braking.
AlpaChino
JB
Indiana
Mach-e Premium eAWD Ext Range, Rapid Red
That progress...
Ford Mustang Mach-E Unusual rotor wear... carl-chef-kiss
veronicablack
New York
Premium AWD ER Dark Matter Gray
I've seen multiple people talk about stopping in neutral. You all mean you just shift the car into neutral while driving and brake? The car let's you do that? For some reason I assumed the computer would override your turning of the PRNDL. How fast do you go when you do this?
The car lets you shift to Neutral while driving, but you can‘t shift to Park or Reverse.
Really? Mine have never looked like that, unless there was a problem such as a sticky caliper. Are your rotors flat all the way across or does it have grooves cut into them already?
Out here we would freak out if our rotors were scored that badly. Even this Porsche doesn't have visible rings....
