Update messed up my Level 1 charging?
7mac11s
WI
22 Mach E ordered 3/18
So early last week I got a few updates and since then I noticed significantly slower level 1 charging.
Also my estimated finish times are now always way off. The app is always showing a finish time of 2-4 hours from plug in time no matter how low the charge is.
Has anyone else experienced this? I've attached 2 before and after pics from the charge logs.
22 SR RWD. Oct 22 build. About 9k miles.
Ford Mustang Mach-E Update messed up my Level 1 charging? Screenshot_20231124-221047_FordPass
Ford Mustang Mach-E Update messed up my Level 1 charging? Screenshot_20231124-221005_FordPass
EDIT: Wrong battery
Level 1 charging will only add about 1.5% per hour to the standard range battery.
Level 1 is limited to 12A or about 1 kW into the battery.
7mac11s
WI
Thanks for the reply. The first photo is how fast it normally
charged since I bought it last November.
I've always used the Ford mobile charger.
Level 1 charging will only add about 1% per hour to the battery. The first photo doesn’t seem possible/accurate. The second photo does seem realistic to me.
With an SR battery, it should add more like 1.5% per hour.
The 1st pic seems close to that.
2nd pic is about 1/2 that speed.
Oh whoops, I did calcs for extended range. Yes 1.5% per hour is expected for SR.
So OP, looks like your charge rate dropped from 12A to 8A. This could because the mobile charger is failing, or because the on-board charger detects an excessive voltage drop in your circuit.
7mac11s
WI
Good to know, thanks!
