jbooth
- Jonathan
- Sep 6, 2021
- Illinois
- Honda Fit, Mustang Mach-E
- Software Engineer
Can anyone else confirm if this is a known issue or can be replicated on your car?
I approach the front passenger door, fob in my right hand. Using fob-hand, hit the unlock button. Door button flashes and it makes noise like it wants to do something, but doesn't. Doesn't unlock, no mirrors out. No door open.
From the same spot, if I hit the rear passenger door's unlock with my left hand, it unlocks and opens fine (fob still near front door unlock button). Also, if I do it quickly enough after the front door, both the rear and the front door will pop open simultaneously, after the rear button is pushed.
I'm assuming this isn't some insane "the driver's door must be the first unlocked" because the rear doors operate fine (either side), as does the hatch.
It could be a fixed software defect, I'm in the stuck-pre-1.7.1 crowd.
