- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
I've seen a few reports of 12V issues solved after disabling welcome lighting, and I think this now deserves its own topic for discussion. I haven't done a lot of testing with it personally since I disabled it shortly after delivery. I didn't have a good feeling about it behaved back then, and my suspicions may have been correct.
I believe the issue is the welcome lighting gets repeatedly triggered when you park in range of the key fobs or PAAK, such as at home. Since it relies on received signal strength (possibly time delay), anything that affects the received signal can trigger welcome lighting even though the fobs haven't moved. Simply walking around near the fob or the car could cause the signal to change and the car might think you are approaching based on that. Old timers will recall how walking around near a TV affected the reception, the effect on fob radio signals would be similar. Your body is conductive and acts like an antenna, which can absorb and reflect radio signals as you move around.
Folks with cameras in their garage could do some investigating to see how many times welcome lighting is activated per day, etc. PAAK vs. fob would also be interesting info. Perhaps standing between the fob and the car to block reception, then walking away might trigger something?
Or, it's possible the process of monitoring for fob signals alone could use too much battery, although that seems less likely than being caused by intermittent signal strength variations. Another one might be if there are other Ford fobs passing nearby (e.g. parking lot) and if it would repeatedly awake to interrogate those?
