JamieGeek
- Dec 29, 2019
- Southeastern Michigan
- Website
- spareelectrons.wordpress.com
- Mach-E, old: Bolt, C-Max Energi, Focus Electric
I know there are a couple of other threads touching on this topic, but I wanted to start one soley for these items.
(Other threads:
https://www.macheforum.com/site/thr...eration-and-during-l2-and-dcfc-charging.3403/
https://www.macheforum.com/site/threads/software-bugs-features-i-want.3709/ )
Despite all the accolades the Mach-E is getting everywhere this is one common thing that the reviewers point out and many people on the Mach-E forums also point out that is missing: Power and Energy meters. I’ll be charitable here and think that their omission is simply due to time: Ford intended to put them on but ran out of time before launch readying other things (and ironing out some wrinkles). There is that token average miles/kWh display on the trip meter page so someone was thinking about it. Hopefully they will add something with one of the OTA updates.
This becomes even more glaring when you compare the Mach-E’s displays with Ford’s only other BEV: The Focus Electric. Its dash has a configurable portion that could display a myriad of options:
The above displays had several areas in which you could pick the meter you wanted displayed. In addition the middle one with the blue “cup” gamified driving efficiently. That one bar chart displays a target Wh/mile (blue cup), an average Wh/mile (white tick marks), and instant Wh/mile (white line at the top).
I don’t really need to see such configurability on the Mach-E (it would be nice but isn’t necessary). My thoughts would be a simple power meter on the dash below the % charge and distance to go (navigation) on the left. This could be a simple number: +/- kW (+ during charging/regen and – while driving). In addition, the power number while charging would be nice to see on a display somewhere when the car is plugged in and “off”. (Maybe the display would only light up when the driver is close by?)
Note that even Ford’s mass market vehicle, the Escape, allows the driver to show average miles/gallon (equivalent to miles/kWh) and instant miles/gallon (equvalent to kW).
As far as energy (kWh) displays the Mach-E has none. The obvious place for this display would be to include it in the trip meters: kWh consumed since the trip meter was reset. Something the Focus Electric also had:
The omission of these items is odd when you consider that the car is called a “Mustang”. Aren’t Mustangs for gear heads? How many Mustangs have you seen with additional gauges on the A-Pillar?
Having said that: An additional card/tile would be really great to have allowing the driver to pull up a bunch of gauges:
Some food for thought…
(Yeah ok this is a copy of one of my blog posts..so sue me LOL)
(Other threads:
- Motor RPM (maybe two for AWD models)
- Motor Temperature(s)
- HV Battery Voltage
- HV Battery Temperature
- LV Battery Voltage
