That's for the physical key fob - I believe you can put it in there and the car will recognize it to drive, if for some reason it doesn't in your pocket. There might be a few other reasons.I can't find it in the manual. I tried coins but they flop around.
Most Fords have this slot. It is for when the key fob battery gets low. It is placed here close to the receiver for the fob. Some other vehicles are in the glove box, all over the placeI can't find it in the manual. I tried coins but they flop around.
I wonder if it will program your quarters to start the carNice to know. I've been using it for change and it works well.
CaaK (Coins as a Key)I wonder if it will program your quarters to start the car
Anyone know how to disable the walk away horn beep? Drives me crazy and I can't find where to disable it.
If your Key FOB battery dies, you place it in that slot to operate the vehicle so car can see the fob with NFC. This is particularly important if you don't have a start pass code setup as a backup.That's for the physical key fob - I believe you can put it in there and the car will recognize it to drive, if for some reason it doesn't in your pocket. There might be a few other reasons.
