- Mark
- Nov 13, 2019
- Sonora, CA
- _______ '20 Shelby GT500 FPB '21 Mach-E GTPE IS
- Retired
I have a ChargePoint HomeFlex as well, and like it for the most part, it keeps track of my charging cost accurately. Two complaints: 1) the app depends on their backend server to communicate with the HomeFlex, over the past six months I have encountered two outages (there could've been more, just not when I needed to use the app), in one case it lasted hours and prevented me from overriding the charging window (I set it on the HomeFlex rather than on the car) during those hours. I don't know about other "smart" EVSEs, but some IoT devices fall back to direct connections when there is no Internet conductivity. 2) they recently removed the ability to change breaker amperage on-the-fly from the app, so I am no longer able to reduce the maximum charging current during the hottest months.
You can change the breaker amperage however in order to do so, you need to remove your charger from the account, then set it back up again. It only takes about 1-2 minutes to do. Even though I do have mine hardwired to a 60 amp circuit, I normally select the 40 amp circuit rating (32 amp charging) because I use only solar to charge. I don't need to charge in a hurry and at that rating, it uses about 7.8kW and that leaves me around 3.6kw of solar power left to run everything else in the house during the day (A/C, etc). I have run it at the 60 breaker setting, 48 amp charging a couple of times when need to charge fast but it pulls 11.5kw which is the max my solar produces at peak hours.Yeah, I wondered what that was about. I was a bit upset I couldn't change my charging from the app anymore. I had to call the 24hr hotline. I wonder if that was a liability issue. Probably had many people who have no experience with electronics, changing amperage on a whim, and causing burned out circuits or worse.
