What's the trick to get the pony puddle lights to come one?
kdryden99
Richard
Montreal Canada
Right...makes sense. So when the car is asleep and no connection exists, and we walk closer to the car with PAAK or fob, something has to wake up the car. I think if we press the fob buttons or some keys on the Ford Pass like unlock then that should in theory establish the connection and trigger the puddle lights. Will check this tomorrow.
Outside of this deliberate action on our part, proximity detection based puddle lights turning ON seems to not be a feature. It may appear that way sometimes but that is only because the car woke up by some means and established such a trigger and hence we feel its inconsistent. I don't seem to recollect reading anywhere that the MME is supposed to say I am ready based purely on proximity detection without action on our part. The PAAK distance guides then turn out to be distance guides to show when the activity from the phone will be recognized/reached by the vehicle.
This makes 100% sense. Plus im sure many are still playing with app so any interaction with the app would make the car react if it coincides with us approaching the car after.
JellyBelly
Kris
MME RR FE
Just a theory, is it possible that if the car loses connection to your fob/phone or after 30mins an hour not using the car, the lights come on?
That is the case, as bluetooth cant establish connection beyond certain distance - I notice Bluetooth disconnected status often in FordPass. But when you get close to it it does not seem to establish that connection right away or quick enough but does so by the time you get t the door.
kdryden99
Richard
Montreal Canada
The fob would most likely interact differently than the phone. The fob has a much more limited range then your phone.
JellyBelly
Kris
MME RR FE
That is not my experience. When I walk out to my car parked in the driveway the puddle lights come on for me without me doing anything - having the fob in my pocket is good enough.
If that is the case, something is working with your setup better than mine. But I have not tried with fob only phone. will have to check that.
JellyBelly
Kris
MME RR FE
For sure - will check that out
kdryden99
Richard
Montreal Canada
So their is first the ack and the the response which could be measured by the latency to determine how close you are to the car.
timbop
Unfortunately PAAK isn't ready for primetime yet.
SteveJo
Chadds Ford, PA, USA
2010 Ford Fusion Hybrid, Job 1 Mach-e/X
I did it just now - with the fob in my pocket when I got within 10 feet of the car the running lights came on and I saw the puddle lights. The car has been sitting in the driveway since this morning, so definitely not "awake".
So my guess is you have not turned on the VEHICLE POWER DOWN TIMER in settings. Correct?
Musbie
VA
Mach E
I test drove one a couple days ago. While they were making a copy of my driver's license, they handed me the key and I walked up to the car outside. I noticed that as I got closer, the car "woke up" and puddle light came on. I believe it was on until I opened the door.
agoldman
Charleston, SC
GT Cyber Orange
Mine have never come on. Not even in pitch black. Vaporware I think. There is no setting for them either. So I'm calling Vaporware till I see them for myself. Then I'll become a believer.
Badger_Prof
Randy
Here is pic of mine in my garage. Works whether I approach with fob or phone. Does not seem to light again unless I leave range and return.
Ford Mustang Mach-E What's the trick to get the pony puddle lights to come one? Pony lamp - 1
JellyBelly
Kris
MME RR FE
pretty sure I left that at the default, which is on IIRC
That must be it as I have power down set to one of the options so it does power down and may then take time to wake up and hence I see it being intermittent.
santa fe,nm
www.envirokarma.org
Solar Sales/install
I cannot get mine to recognize phone as key, even though it paired ok
