When will job 2 MMEs get improved charging upgrade?
DrAchoo
Jason
Oregon
Premium Rapid Red RWD, St. Batt Mach E
Of all the upgrades released, the one that I am most interested in is the lowered time to charge from 80% to 90% when on the road. My most likely long-distance trip I make is Eugene, OR to Seattle, WA at about 300 miles and the difference of being able to get to 90% instead of 80% quickly can make a tangible difference in my trip time (generally on my way back I don’t start with a 100% charge).
I haven’t seen a single OTA upgrade other than the update of the BlueCruise map. I’m not missing anything, am I?
“Soon?”
Probably after the 2021 Job 1 cars get the BlueCruise PowerUp’s. I’d anticipate that to occur over the next couple of months. This is just a guess on my part though, neither Bill Ford nor Jim Farley confide in me their plans for the Mach-e. Rather rude of them, but what can you do? ;)
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
If your car was built before Sept 30 2021, you can have the dealer update your car with the new charging curve.
DrAchoo
Jason
Oregon
This sounds a bit too simple. Can you elaborate? My car was built in July, 2021. I just call and ask and they will do it? I need a reason for them to do it? It's covered under warranty?
Only for non GT correct?
It applies to GTs also, as long as the manufacture date is 9/30/21 or earlier. The note about "non-GTs" is leftover from before they extended the date range.
Silver Lake
Au Sable Forks NY
F-250 , Honda Crosstour, Rapid Red AWD ER 7/15/21
Any idea when Mach Es built after 1 Oct 2021 will get 21P22?
called my dealer yesterday and they said they could not install it yet on my vehicle. My Mach E build date is 18 Oct 2021.
