jgillmer
- Joe
- Jun 26, 2021
- Alexandria, VA
- Shadow Black MME GT w Panoramic Roof & BlueAssist
- Nonprofit Executive
I have owned my MME GT since Halloween 2021. I am close to using the last of the EA credits (500 to start - down to 49). I travel largely in the mid-atlantic states of PA, DE, MD, DC, and VA, and it seems EA and EVGo are the most frequent DCFG networks, and Chargepoint, Volta, Sema-connect, and Blink are the most common public L2 chargers (mix of free and charging).
For those in the same area, do you find value in picking up the plans for EA and EVGo that have monthly fees with 10-25% lower rates than pay-as-you go, or is it better just to have base plans with no fees?
I have traditionally used DCFC about once a month, but recently a bank of free L2 chargers very close to home shut down when the business that provided them was sold. The new owners promptly cut the power to the stations. This means I may more frequently find I'll need to tap DCFC for work travel during the week.
I have a Juicebox 40 at home, but the better half prefers I fill up elsewhere whenever I can - We have installed solar and high efficiency HVAC/Waterheater/Appliances over the last 5 years that combine to finally get us just to 100% net coverage of our annual electric use, but if I tap the house for the car, we go tumbling back down the proverbial hill.
Recommendations? And should I be aware of plans that would need to be tied back to the FordPass and Blue Oval Network?
Thanks!
P.S. FWIW- My experience with EA chargers has been fairly good - connects easily and rarely throws a fault. Plus, most are 150 kW or 350 kW stations, which functionally means 128 kW rate for the first few.minutes and then in the 90s to 80%. The EVGos have been a bit more challenging at times to connect; many of their DCFC are set to 50 kW; and too often charge by the minute. But, the EVGos are plentiful in Northern Virginia.
Thanks!
