jonkMACHE
I’ve put 5000 miles on the car. One time in cold weather the side view mirrors didn’t auto retract when I remote locked the car. That’s the extent of my problems.
Here's a point you have, perhaps, failed to consider:Most if not all forums are just like the mainstream media.
Negative info always gets the most attention and people run with it, then it turns into repetitive gossip, and people start to believe it.
Every vehicle, from every make, ICE, Hybrid, or full EV had problems when they first hit the market and it usually takes 2-3 years before these types of issues are solved.
Not every Mach-E is affected.
Some vehicles are just built with a bad batch of parts and there’s nothing Ford or any manufacturer can do about it because these parts come from outside vendors.
If you’re worried about the Mach-E because you’re reading all of the negative post, then your worries should be aimed at any new from the ground up vehicle.
There is no such thing as a perfect vehicle and all of the issues that you’re reading about will be covered under warranty.
Don’t let others dictate your choices.
Steve Prewitt understands what's inevitably going to happen.Hopefully it will get a better reception than George Diones’ letter to the editor in the May issue. The responses from a couple of members on page 11 of the July issue indicates there’s still a fair amount of resistance to the Mach-E. At least President Steve Prewitt seems to be welcoming, unlike Donald Farr or John Clor. Farr appears to be reluctantly accepting things, but Clor comes across as downright hostile.
But if you are in the know the first few years of the Model S had a similar issue. Tesla redesigned and it has not been a problem since. All manufacturers are gonna have issues I expect that hopefully Ford is kind and takes care of us early adopters when they fixHere's a point you have, perhaps, failed to consider:
From the first introduction of the GT, people have decried the "5-second-limit" on full-throttle power with the the Mach-E...a limit the Tesla Model 3s and Model Ys DO.NOT.HAVE. That indicates to me that Ford knew, FROM DAY 1, that the contactors on the Mach-E were under-spec'ed and inadequate. This problem should NEVER HAVE HAPPENED, PERIOD. Fix it, Ford! It's your problem, not ours.
Ummmmm, don’t you think what you just said falls into my earlier reply.Here's a point you have, perhaps, failed to consider:
My major at UCLA was engineering. I'm saying the parts were inadequate because:Ummmmm, don’t you think what you just said falls into my earlier reply.
Also, since you just admitted that you knew the Teslas’ DO NOT HAVE the feature, why are you complaining about it on the Mach-E?
That sounds like a you problem because you didn’t purchase a Tesla.
With that being said, are you an electrical / mechanical engineer?
I doubt it so why are you saying that said parts are inadequate.
I have a Mach e GTPE, and have not had one problem 10 k miles. I did have a flat tire.I frequently visit this forum, and constantly, I see cars have bricked, there are recalls that only provide software update but not hardware update, charging issues, and easy damage to body of the car issues… I’m sure there are more issues to list, but this is what came to mind instantly. I even saw someone that said they were backing out of their order because they know that the cars are not being made correctly, thus the recalls and such…
That being said, has there been anyone without issues? I ask because 50K+ is steep for something that doesn’t sound reliable. Every time I get on here, there is a new fear that I could be making a mistake.
Someone please share some good!
yea , they are pricey and new- so if there are some hiccups well we all could have waited(we are south of new braunfels by the wayThank you everyone for your responses! I didn’t expect the thread to have this many responses.
For those of you saying don’t come to the forum to see complaints, I found this forum through google and I did not expect so many “complaints” when coming. I honestly had an initial interest in finding out real time for how long it was taking people to get their vehicles. I actually got very lucky and took over a canceled order at a dealership in San Antonio (2022 Space White Premium AWD Standard Battery). Build started 5/26, Built 6/13, and now just waiting arrival.
I am not one to purchase vehicles over 50K, honestly because as a mother, I never splurge on myself. And I know this is Fords first full EV, so I expect there to be minor issues, but I definitely didn’t want to end up with a lemon. People definitely do come to forums or reviews usually to complain vs state the good, so I’m very grateful for those of you who responded with the good, because it’s making me feel like this $55,057 vehicle is about to be worth it!
Thank you all!
Have had my 21 Premium since January about 9100 miles on it and had no issues PAAK works CarPlay works however I do have to manually connect at times. I’ve driven mostly highway speeds so DCFC has been used frequently even in hot weather. I drive like I drive all my vehicles around 70-80mph on highways hard acceleration when needed. I don’t worry about about efficiency I just drive (past range anxiety stage). It’s been a blast driving and random weekend trips with the family to go chargers with in the state makes small adventures to places we would not normally consider going something we would of not considered doing in other ICE vehicles. We still have on the list to check out. Blue Cruse work as it should and helps with fatigue. It’s my first EV and I enjoy it. If my vehicle bricks tomorrow I will look forward to it being repaired so I can get back on the road. (Old mechanic and seen vehicles broken for many things…. eh oh well fix it and let’s go!!)I frequently visit this forum, and constantly, I see cars have bricked, there are recalls that only provide software update but not hardware update, charging issues, and easy damage to body of the car issues… I’m sure there are more issues to list, but this is what came to mind instantly. I even saw someone that said they were backing out of their order because they know that the cars are not being made correctly, thus the recalls and such…
0 issues here. 5k miles, Premium RWDI frequently visit this forum, and constantly, I see cars have bricked, there are recalls that only provide software update but not hardware update, charging issues, and easy damage to body of the car issues… I’m sure there are more issues to list, but this is what came to mind instantly. I even saw someone that said they were backing out of their order because they know that the cars are not being made correctly, thus the recalls and such…
