RedRider
- Randy
- Feb 26, 2022
- Johnson City, TN
- Ford Mustang Mach-e
- Attorney
I'm loving my MME but after a week I'm wishing I had more data-
1. After a charge, I like to compare the charger input kWh with what the Mach-E says it got. You get this information in the Ford Pass App when you first finish charging but then that bit of information disappears from the log. Why? It helps pinpoint charging efficiency. I just have to make sure to get it immediately before I start the car.
2. Shouldn't we get something live - like kW currently being consumed? I know "This Trip" shows some good stuff but the dash could show a live value. I'm sure this metric goes into driving efficiency. Why can't I see it?
3. In my Fusion Hybrid you get lots of feedback on charging while coasting & braking. The MME braking coach is fine (shouldn't you get it in all three modes?) but it would be good to know (how little) kWh you actually add back on coasting and braking. I've been lucky enough once to catch a percentage uptick coasting down a very large hill on the interstate. I'm sure it had just clicked down a percent before the crest of the hill but it made me happy to add something back!
4. Battery Temperature. Why can't I see the battery temp? Not that its necessary but this is monitored and the batteries undergo heating and cooling as needed. I'm sure they have a wide operating temp range but it would still be nice to educate myself on the values and when they need heat and cooling.
5. Motor Temperature. I'm sure this is monitored, too. Again, its just fun to watch these values and with a technical wizard of a car there's no reason to be hiding so much info.
6. Sure glad I have tire pressure!
