D4rkt
- Paul
- Feb 18, 2021
- Melbourne, FL
- 2013 Ford Escape, 2021 MME Premium ER
My Mach-E has developed a condition where it will not charge on my home Level 2 charger. This came about last Wednesday night. I plugged my car in that night and when I woke up I discovered it had not charged at all. Here's what I managed to assess over the past several days.
1. My Mach-E will not charge on my home EVSE (Grizzl-E) level 2 charger.
2. My Mach-E will not charge using the vehicle supplied Ford EVSE using the 240 VAC plug
3. The Mach-E will charge using the vehicle supplied Ford EVSE using the 120 VAC plug.
4. When trying to use the Level 2 charging system after about 30 minutes I receive a "SERVICE VEHICLE SOON" notification on my dash display along with an amber wrench icon in the info window below.
5. Both the vehicle charge port and EVSE indicator lights indicate that the car is charging when it's not.
6. I have uninstalled and reinstalled the FordPass app and established my charging preferences again (Plug in to charge anytime).
7. I have also established my charging preferences via the main vehicle screen via the CHARGE window.
8. I have not attempted to DC fast charge the vehicle since a DCFC station is not conveniently located in my area.
I took my vehicle to the dealership and had them look at it on Friday and they said they could not find an issue with the charging system. I found out that they only put the car on a level 1 charger which as I mentioned above appears to work albeit painfully slow (2-4 miles range per hour charge). I plan on returning to the dealership armed with my new data and photos. In the mean time any ideas on what the problem could be? A bad AC-DC converter? Does a block diagram or simple schematic exist that show the components of the charging system? Thanks.
