Wrong location for Target Charge in FordPass app
invalidname
Grand Rapids, MI
2024 Mach-E AWD Extended Range
I've had my Mach-E for almost two months and the Ford Charge Station for about one month. I was thinking about setting up a Target Charge, but I notice that in the list of locations (as well as in my Charge History) that the address is wrong. Not a huge deal, just off by a few house numbers, showing "751" when we live at "770".
Is there any way to correct this before I set up Target Charge? Does it even matter, or is it just cosmetic? For what it's worth, the charge station has the correct address when I look at it in the app.
Thanks.
jtmyrand
Gerald
Grosse Ile, MI
2023 Mustang Mach-E GTPE, 2023 F-250 Super Duty
IT Consultant
To make change:
Energy
Target Charge
Click on the location you want to change
Click on the pencil for Location Name you want to change
Make the change and save
Kyle
Kyle
Minnesota
Mustang Mach E Preimium
Mine was off too, it said 270 in my address instead of 265. I deleted it and the next time it charged at home it added a charging station that had the correct address. :oops:
Snakebitten
Coastal Texas
2023.5 Mach-E
My EVSE is about 1200' from the road front and my private road crisscrosses 2 numerical addresses (5 acre lots, based on county records) as it winds its way through the property. The house is on one lot, the barn on the other. And the EVSE is located at a 3rd spot where I have the RV kept.
However, I think the real location for the EVSE is a longitude/latitude value? I know I saw it in that format on either FordPass or the Sync screen after charging a couple of times.
I did a similar edit to the suggestion above, but designated it as "Home", rather than a numerical address.
It works reliably and even Alexa recognizes "Alexa, Route me home"
The address the car and FordPass show for our place is significantly off and has been for almost 4 years. The car is a detached garage away from the main house while the car thinks it's at my neighbor's address which is 1/2 mile away. It hasn't affected the charging in the slightest though. Edit the name to something else as @jtmyrand suggested if it bothers you.
