2022 Mach-Es
Scott
Norfolk, UK
Mach E AWD ER
Hey all,
I've been searching but there doesn't appear to be any "recent" updates on any of the following, just wondering if anyone can comment as I'm still a new Mach-E owner?
* Frunk button in app - Will we ever have this or is it a "who knows" type of deal...
* Does the keypad on the door allow for vehicle start/Can I enter a keypad on the screen aswell? It appears not, but wanted to confirm I wasn't missing anything
* When listening to DAB, the bar keeps coming and going every minute or two that says what station I'm listening too. Seems a common problem, but anyone know if this is addresses in later updates, or any plans to?
* Do we receive different updates and verisons to the rest of the world? I.E There's not really much use in following the updates that the US gang get?
Thank you for any help you can provide :)
grovep
Manchester UK
MME extended range
Hey all,
Hi Scott, I'm sure there are others better informed than myself but I understand you should be able to enter the car using the door pad code and then start the car using a code that you preset on the main Sync screen. I think I read it in the manual somewhere. Never done it myself.
The UK spec is very different to the US different towing setup, no bluecruise, no phone as a key .....
My DAB does cut out due to poor signal in certain locations even around Manchester. I put it down to an inferior aerial/setup compared to my previous car. However different stations are on different muxes which have different signal strengths. I find the BBC channels have a stronger signal. Is this what you mean re the bar coming and going?
No idea re the Frank Button. Personally I'm not too bothered by this.
Thanks
