Anyone else getting this message on screen?
93940 Monterey CA
Mach E
“System Off to Save Battery,” appears regularly when re-entering vehicle; no performance issues that I can detect, have assumed there’s a proper sequence for shutting down possibly…
That means the 12V battery is less than 50% charged. If you have a 2021, you should replace your 12V battery ASAP if you still have the original one. Any warning messages in FordPass about battery drains?
Make sure you are not using accessory mode (green power light flashing) because that will drain your 12V battery.
