Charging limit
Jefe 70
Jeff
Home
2021 Ford Mustang Mach-e Premium
I am charging in my garage on a 50 amp outlet which has always worked perfectly. Now indication is 80% would only be 99 miles vice usual 80% range of 221 to 230 Miles. Amber light is on the mobile charger though I am running a fan and have garage door open. Ambient outside temp is upper 70s. Is mobile charger the issue? Forgot to mention speed also is down to 5kw rate.
thanks for any help
JoeDimwit
Waterford
Grabber Blue First Edition
Electrician
Yes.the mobile charger is your issue.
Jefe 70
Jeff
Home
Thank you, thought it probably is. However is that also causing limit issue, that is saying 90% is 99 miles?
No, it’s not causing your oddball low Guess-O-Meter estimate. If you have driven the car really hard recently, the car’s system may guess low. You may want to do a master reset to make the GOM unlearn it’s guesses. ?‍♂?
Auto Motive
Doug
Valencia Pa
thanks for any help
Its a pc of junk. We had so many issues in summer with high temps. Bought the juicebox 40 with plug and have a 50 amp circuit. Works perfectly getting 25 miles hour. Our tesla y gets 35 miles an hour. Amazon cost $650
