Discoveries Post-Delivery
ChuckInFlorida
ChuckInFlorida
Chuck
Ford Mach e
Same here. Paak works flawless on my S21. I also tell android to run it in restricted mode. In restricted mode there's zero battery drain and Paak only works after I open the fordpass app. This is perfect IMO
I'll have to retry PAAK setup. It did not work on my S22 Ultra.
TGIF
IA
Then this happened.... driving through a construction zone where they alternated thru traffic, you know, one side has a stop sign and other has Slow, then they take turns.
As I was nearing the end of the section. about to merge back into my side of the street, and facing waiting oncoming cars, the Mach suddenly went into Panic Mode! Red warning lights flashing, loud alarms, and me about jumping out of the seat!
Preventing an accident almost caused an accident! How sensitive my new pony is! ?
Horses can be very high strung, you know.
ChuckInFlorida
ChuckInFlorida
Chuck
Ford Mach e
Reset PAAK - works fine now. But, I keep leaving my phone on the charging pad so the car doesn't lock. I turned on the horn notification for "locked", and I am in the habit of listening for it now. Amazing how anxious we feel when we realize our phone is missing!
ChuckInFlorida
ChuckInFlorida
Chuck
Ford Mach e
Cargo space has two deck levels.
Added a Ford parts cargo mat and adjusted the deck. (WAYYYY overpriced but used FordPass rewards points and got for free.)
I lowered the cargo deck to rest on a more solid surface. Read other posts about the support tabs breaking when loaded with too much weight in the upper position. Upper position should only be used when seats are down and a level surface is required.
SWO
MD, USA
Enter your unlock code then hold the 7-8 button to open the frunk, or the 5-6 button to open the liftgate, or the 3-4 button to unlock all doors. ??
Does that work on Job 1 cars, or only Job 2?
It only works on cars that already have remote frunk lid functionality, which is anything post-21Job1. Not sure when Ford is going to OTA the 21Job1 cars so that they have remote frunk lid release. ?‍♂?
ChuckInFlorida
ChuckInFlorida
Chuck
Ford Mach e
Android Auto v regular Bluetooth. Thoughts?
