Does the battery contain a heating element?
Carsinmyblood
Mitch
Western NC
Self employed
If so, is it heated only while the EVSE is plugged in?
Carsinmyblood
Carsinmyblood
Mitch
Western NC
Self employed
No. It uses the same PTC heater that's used to heat the cabin.
So, the battery is heated via an external source on-board the car.
1. Does it heat the battery when plugged in?
2. Does the battery use it to heat itself when not plugged in?
It is capable of heating the battery when plugged in or not plugged in.
The high voltage battery is heated and cooled with liquid that circulates through some plates mounted inside the battery pack casing. Heat transfers from the liquid, through the plates and into the cell packs bi-directionally.
The HVB is supposed to heat and cool itself when plugged in.
The HVB should heat or cool itself for scheduled departure times. I believe there is a setting in FordPass to allow departure times to function off plug.
