Driver’s side Automatic Window Not Working
Kluginbyhl
Kyle
Gilbert, AZ, USA
2023 FMMe PremiumX
Healthcare
Ok I know it’s a bit petty but one of my very few complaints a hot my 2023 MME Premium is that the driver’s side window doesn’t automatically roll up with just a single pull of the window buttons. However, today I realized the passengers side DOES. Is this a programming issue? Does anyone know how to correct this? Any help is appreciated!
tbrumleve
Tom
Oregon, USA
All operating information is in the manual. Check there first. Second, search the sub.
In the manual, under “Windows” / “Opening and Closing the Windows” / “Resetting one touch close”:
“ Resetting One-Touch Close
Carry out all steps within 30 seconds of starting the sequence.
1. Close the window.
2. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a few seconds.
3. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a few seconds.
4. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a few seconds.
5. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a few seconds.
Note: Repeat the procedure if the window does not close when you use one-touch.
Ford Motor Company
Official Ford Account
Good morning, I would like to see if I can assist you further on my end with your window concerns. Could you please send us a message with your VIN and mileage?
