CzarR
- Vrn Kmr
- Nov 13, 2022
- Dallas TX
- 2022 Mach E Premium ER AWD
Ok, got you. Good to know.the signal provided by the blue wire is “digital”. Everything is sent unfiltered to the pac interface, where it then can be output to either digital or analog rca. The pac interface is your limiting factor. You will get 6 channels , not 6 speaker outputs.
you can then decide which speakers you want on each of those 6 channels. 99% of people will have front (L/R) , rear (L/R) a center channel (Mono) and a sub channel (also mono) .
ThIs assumes you plan to use 2 pairs of a 2-way component speaker system of your choosing ( tweeter and a mid/woofer ).
I am thinking of taking Pac's TSOlink output(digital) to Helix V8 DSP/AMP 8 channel which will power all speakers. I will add another amp(subwoofer) and subwoofer. You think this will work.
