Sabbaspar
- Sam
- Oct 11, 2022
- NEW JERSEY
- Mach-E
I was able to pick up the hub covers from Amazon like others have done. In the blank space of the hub cover I put a 44mm dome shaped mustang sticker (Sticker was from Etsy).
Link to Hub Stickers from ETSY. Must select 44mmsizee
https://www.etsy.com/listing/1298318290/set-4-all-sizes-print-surface-mustang
Link to Hubs, must be glued into the wheel. I used silicon but I'm not sure how wheel the glue will hold. X AUTOHAUX 4pcs Black 64mm Dia 4 Clips Wheel Tyre Center Hub Caps Cover for Auto Vehicle Base Outer Diameter 58mm https://a.co/d/5C5wLqy
