How do I clean out all the charge preferences?
DMWARD
Kenilworth
Mach E
Commercial Photographer
Just recently it seems that the Mache only wants to charge during certain times.
Up until now it has always charged to the preset amount whenever I plugged it in.
How do I clear all the setting out of the Ford App, which seems to be doing this, so the car will charge to preset whenever it's plugged in to ChargPoint charger?
Click on the energy button at the bottom of the Ford app's home page (aka FordPass); it looks like a lightning bolt. Scroll down and find charge settings, then click on preferred times. Click on the times under each charger that is listed and delete. That should do it. You can also do all this in the Charge app on the mach-e's home screen. This might be a more effective way of doing it. If none of that works, reboot sync. Why reboot sync? Because that's the stock answer for every glitch in this car. Sometimes it works too. :)
DMWARD
Kenilworth
Mach E
thanks for your help
Bad Dolphin
2024 Mach E GT
also when I'm the charging section as described above, select Departure Time to check that that is clear, too.
