How do I change the address in charge setting in Sync?
coolshades
UK
Jaguar XF -> Mach E AWD ER, Rapid Red
I wanted to change some charge settings on the car and noticed that my Home showed a very different address and tin a different location on map.
how can I edit it?
Or, how can I add a new address?
To set a new home charge location, you need to delete the current one. Then, start a charging session. After a few minutes you can stop the charge, then save the location as Home in the charging menu.
coolshades
coolshades
UK
why did Ford have to make it so complicated!
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Been that way for years: The 2012 Focus Electric worked that way. You have to charge somewhere first before you can add it as a charge location.
In addition: Sometimes the address doesn't come up like you would expect but that will be your charge location (even if its a few numbers off).
Right. Ignore what it says. As long as you're home, and it says home, that's all that matters.
