Interesting article on charging
Maui
Austin, TX
2024 Mach-E Premium
Software
Yes very interesting. Didn't old fuel tankers drag a chain to provide a path to get rid of built-up static energy? I am not saying we do that here, but this article does make me think of that solution.
cyeung
Atlanta, GA
2025 Mustang Mach-E Premium
I honestly cannot believe that half the cost of an EV charging station is measures to keep us safe! Now the question that the article does not answer is: What retrofits would be required to implement this solution?
rreddy3
Richard
2023 Mach e Premium AWD X
The answer to your question is, “yes”.
I am old enough to remember seeing the dragging chains.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
Thank you for sharing this article. Interesting stuff indeed. I shared the article with an electrical engineer friend of my who also owns an EV to get his take.
If what the author proposes is accurate and technically feasible, implementing on the DCFC side of thing would seem fairly straightforward since it wouldn't require changes in the EV. For level 2 charging however, it would require an entirely new charging standard since it would be a lot of the isolation onus would be put onto the EVSE instead of the EV's OBC. But if there is a way to handle that transition, it could be a good thing.
Edit: my EE friend notes that the infrastructure costs of a DCFC station are quite substantial, so reducing the service equipment cost wouldn’t necessarily be sufficient to move the needle on a big way.
