Mileage
Leolivan
Leo
Stroudsburg, PA
Mach-E
My fully charged battery on MME premium standard range eAWD shows 210 miles range. I drive to work 72 miles. By the time l pull into parking lot my remaining range shows 110 miles. On a 72 miles trip my car uses 100 miles of range miles.
mid I don’t charge up at work, I come home with 7-9 miles left.
Is it normal? Or am I doing something wrong?
I use blue cruise most of the way to work and go at 70mph.
Yes, that's normal for the first 500 miles while the range display adjusts. You are driving 144 miles on a charge which should be fine unless it's very cold outside.
Make sure you are setting a departure time in the mornings and plugging in L2 every night so the battery is warmed up before leaving. That will give you more range so you arrive home with a bigger buffer.
alexgorod
Alex
DBA
No, it won't if you have 3.6.2 update. GOM keeps showing a very optimistic range until the battery charge drops to 20% or so.
Ignore GOM until summer and come up with some calculation that serves your case. (I multiply the battery percentage by 1.5 to estimate the winter milage for my standard battery)
