Navigation Bug?
intensifi
Jeff
San Mateo
GT
I used the factory NAV on a trip from Silicon Valley to Los Angeles.
Factory Nav added two charging locations.
I charged before the second location. However the Nav did not reset to skip the second charging location. I ended deleting the trip and starting over.
Is this a bug?
Love the big blue blobs BTW.
‘23 Mach E GT (delivered 12/22/22)
@Ford Motor Company
Yeah it doesn't recalculate if you charge off route. Ford needs to fix that and update the route about every 15 minutes. Right now you have to manually end and recalculate the route if you want an update on charging stops.
It's also an issue if your range consumption is way less or more than the Nav is calculating, so you might not make the charger the Nav is sending you to, or you might be able to skip a charger and make it to the next one.
